OBDII - CarChip E/X specs for Corvette
Old Oct 11, 2006 | 08:28 PM
wandrew1's Avatar
wandrew1
Default OBDII - CarChip E/X specs for Corvette
I recently bought the carchip E/X. No tools or automotive expertise required! Just plug CarChip into the OBDII port (easily found under the dashboard or steering wheel) and you're ready to roll. Once installed, CarChip reads and stores data from your car's on-board computers, continuously logging driving and engine performance.
http://www.davisnet.com/drive/produc...p_products.asp
I have a 1998 Vette with 52K miles. Can someone tell me:
1. What is the optimal Air Flow Rate?
2. Optimal Intake Air Temp?
3. Optimal Fuel Pressure
4. Intake Manifold Pressure
Old Oct 12, 2006 | 06:46 AM
JCR's Avatar
JCR
Correct me if i am wrong, but i believe that you already have on board diagnostics . If any paramaters are out of whack you will know when you do an on board diagnostics check. This device only repeats what you already have. What is the advantage?
