Anyone have this scenario, I was sitting at a stop light at idle, when I noticed my fuel guage(which is at 3/4 level)all of a sudden the needle went to empty, stayed there for awhile then went back to 3/4, I drove a little longer, was sitting in a parking lot for wbout 10 minutes waiting for my daughter to get out of work, then started to drive again and this time a "low fuel" message showed up and a red "check guages" signal also showed up, then it went away, drove the rest the way home and nothing popped up after, Is this a sign of something possibly going wrong.
My vehicle sits in the garage, has never been wet,or even close to rain since I purchased the vehicle last x-mas, so corrosion of some ground could possibly be ruled out, but not totally I guess, any other suggestions on what to look for.
I had something like that
we donated a computer, and loaded it in the car. we went to deliver it, I had half tank. and arrived, shut the car off. 15 minutes later,
back in the car, turned the key, and it was below a quarter tank.
we made one turn to get out of the parking lot, and it dipped, popped up to full, and back to where it shoud have been
almost like loss of a ground or power
we went to get gas cause I didn't trust the gauge, and it went to full, and then dropped, went empty, and was ther for like 3 minutes, then has been normal since.
that morning, we went through a rain storm that we could hardly see the end of the hood go figure
I have only used Chevron premium in all of my cars from day one.
Hmmmm....te C5 has electrical gremlins as you may know. It may not happen again. It's great that you are using the right fuel.
A few weeks ago I had to put in a 1/4 tank of Shell and a week later I got the same thing have happened and that was after few fill ups with, for now I haven't had it to happen lately.
So it may help to put a can of Techron in the tank. Good luck
I would be careful puting Chevron fuel in your cars. I put Chevron in two of my past vehicles, 98 Dakota R/T and 02 C5 Coupe, and had detonation in both vehicles. As soon as I put Exxon fuel in either it went away. The Two fuels I trust most are BP and Exxon. I go with Exxon because there are two stations here in Auburn that have excelent prices. I have always heard Amaco(BP) is the best fuel. I know it's rated the best by consumers. I'm not saying that your problem would be solved by not using Chevron but if you ever hear what sounds like rocks in a tin can when you are WOT then I would reconsider your fuel choice.
I have always used Chevron premium in all my performance cars, Vettes, Cobras, Saleens, I only used Shell in my Porsche because it was recomended by the Manufacturer.
You probably just got a bad batch of fuel from that particular station you filled up at that time.
That usage was over years. I'm not saying that your cars will have problems with Chevron but mine did. I stopped using Chevron and my car has never had any detonation problems again.
Your right tank fuel level sender is probably dirty. It’s common problem. Techron helps clean it. The way most cars work the sender is submerged in gasoline almost all the time. Your Corvette has two gas tanks. The way the Corvette fuel system is plumbed the right sender is only submerged in gasoline until the fuel level goes below ½ tank. Then the right tank is empty and the sender is in gas fumes only. What little gas is I there splashes on the sender and evaporates leaving the solids from the gas. If you are mechanically inclined, the sender is not too hard to clean. If you clean it you will see the problem. The resister will have some build up on it causing some of the windings to short out and cause an incorrect output. Do a search on fuel sender and there should be a procedure on how to get to it. A pencil eraser and some contact cleaner work well to clean it. If you use techron make sure you have at least ¾ of a tank of gas or you won’t get any techron into the right tank. My experience is that techron works somewhat but cleaning really works.
Yea, Chevron is good, but it won't help the fuel gage problem. The dealer needs to reprogram some computer. I had mine done and it has worked for years now. That's after they COMPLETELY replaced the entire fuel system, tanks and all.
thanx
Yeah thats happened to my Z06 on two occasions in 4 yrs..both times it corrected itself and both times it happend after either climbing or desending from alititude..I dont know what if anything that has to do with it but driving around my town locally my Z has never done it.But it resets itself.
thanx
You probably just got a bad fuel from the station you filled up at last time or it's build-up on the sending unit. Techron cleared up my problem for a shot time, but it does return after a while. Might be time to try and clean the sending unit.
Yes, on my 03. Went to empty, and I bought gas, and It stilled show empty , than It began working again. I saw here where I needed to clean a groung at the rear wheel well.
