Drone Defined and Resolved
Let me start by giving you my background... Years ago I spent a great deal of time designing and constructing audio systems for IASCA show cars. I have an engineering and musical background and currently work for a precision measurement company.
Many people have described drone in different ways. Some associate the term simply with volume and others with increased volume at a certain opearting (RPM) range. Manufacturers often refer to it as "resonance". For my purposes, I define drone as the disproportionate increase/level of volume at a specific engine operating load... here's some explanation...
When I used to build sound competition vehicles, it was a commonly known fact that each speaker enclosure, especially the ported or bandpass variety, had a range of frequencies that it would be most efficient. A properly tuned speaker enclosure dramatically increased (amplified) the amount of volume for a specific range of frequencies. In addition, the shape and size of the car in which the speaker/enclusure operate (the listening environment) will also have a range or collection of ranges in which it is most efficient. The net effect of the speaker/enclosure/listening environment is similar to that which can be observed in a lake; when waves meet, they either cancel eachother out (opposites do this) or reinforce each other (similar waves do this). If reinforcement occurs, the result is a much bigger (more powerful) wave. Sound Pressure Level (SPL) vehicles, for example, compete to make the most powerful wave and rely heavily on wave reinforcement to make this happen. As another example, take a soda bottle and blow over the top. You have to blow on it just right to make reinforcement occur and the bottle "drone"
So back to our Corvettes. If you think of our engine as the speaker, the exhaust as the tuned enclosure, and the interior of the car as the listening environment, you can start to figure out how to address this issue. The interior of our cars provide a reinforcment potential for a specific range of low frequencies. This is inherent in the Corvette model design and does not vary from vehicle to vehicle. Because the interior of a Coupe is different from that of a vert or a FRC, each model will exhibit different reinforcing capabilities. Of the three, you will hear the coupe owners complaining about drone because the coupe offers the most potent reinforcing environment (with the removable top in).
So how to combat drone? Five choices:
1. Tune the exhaust to minimize or not hit that specific range of undesirable frequencies (e.g. Corsa)
2. Make the exhaust system quiet as a whole so it doesn't provide a powerful enough note at the specific range of frequencies (e.g. Stock exhaust)
3. Sheild/dampen the vehicle from incoming exhaust noise (insulation, dynamat, etc.)
4. Modify the listening environment (roll the windows down, take the top off, etc.)
5. Ignore it or shift to get out of the engine load (rpm) at which the drone occurs
The above choices have all been performed by forum members and have been proven effective in combating drone. Which route you choose is highly a matter of personal preference. some poeple like drone and don't eliminate it at all.
I've typed enough... now your turn!
1. Don't want to pay the $$$ for a well designed exhaust like Corsa (myself included).
2. Don't want the restriction and loss of hp associated with a high backpressure (quiet) exhaust.
3. Don't want to insulate/mat the interior to solve a problem GM "should have anticipated".
4. Don't want the extra noise from having windows open or top off.
5. Don't want to lose fuel economy by shifting to a different gear.
I agree with all of your proposed solutions...just offering a counterpoint from what I have heard from various threads.
As a side note I have quite a drone with my Borla Stingers, LG street LT's (no cats) and some rear compartment insulation. I'm looking into changing out my mufflers in an attempt to reduce resonation...
As for a cheap and simple help, install lock washers between the rear muffler hangers and the frame.
I was telling Jim that at the beginning it was 109 db behind my head. This weekend I'm going to setup the meters just to see how much it has dropped. Sometimes I felt like a mac truck driver having to make sure I hit the right RPM on the tach so I could stay out of that drone range...call me old fashion but I just like to shift by feel not drone...
Knowing how some people can take comments on forums This in no way should be taken as disrespectful to anything concerning deafness please, just an example . The drone is what can be disrespectful
Hoping not OOffend
Jarad
Period.
No drone.
No resonance.
Period.
GHL.
Get it.
Smile.
Period.
Funny - my wife was not affected by them at all and, in fact, was upset when I removed them from the car. People are affected differently by the same frequency/power combination.
Anyway, I bought a set of Z06 Ti's, installed them and sold the Stingers (Tearfully, I tell you. They did sound awesome.)
Then I decided to try a set of cutouts. Installed them and have been happy ever since. Cutouts closed, the car is somewhat agressive, yet controlled with no drone/resonance, and I can drive for hours with the stereo easily heard and without "sound fatigue". (I did insulate the entire interior during the Stinger episode.) Low volume conversation is even easily accomplished with the windows and top in place. With the cutouts open, very aggressive, very mean-sounding. As good, if not better, than with the Stingers. Dogs run and children cry when they hear the open cutouts. But very little to no resonance, depending on the valve-opening setting. The "tuned enclosure" is significantly different than with the Stingers but the "speaker" and "listening environment" have not been altered since.
For me, a nice compromise.
long tubes, no cats, x-pipe...loud at WOT, no drone, and stock quiet at highway cruise speeds.
Hey Duckvett...Nice car!!
Period.
No drone.
No resonance.
Period.
GHL.
Get it.
Smile.
Period.
Interesting. I had all kinds of drone with my GHLs. But wow, I love the sound of that exhaust.
