why is my battery going dead??
Old Oct 12, 2006 | 03:04 PM
bayarea's Avatar
bayarea
Default why is my battery going dead??
I hit a curb really hard and broke my front impact plate. now after that I have to jump start my car every time just to start it. it will hold the charge for a lil while. I never had a problem with it before......its the ac delco batt.
what gives??
Old Oct 12, 2006 | 03:40 PM
hotwheels57's Avatar
hotwheels57
...if you hit something hard enough, it's possible to do internal damage to the battery I suppose, especially an oem lead acid design. If it's the original battery, it might just be a coincidence. The original batteries do tend to fail w/o prior warning.
It's also possible the impact has caused something to short out drawing current when it shouldn't be.
Did you check the battery terminals to confirm they're still tight?
Old Oct 12, 2006 | 03:47 PM
GrayC5's Avatar
GrayC5
Several possibilities; i.e., loose or corroded battery terminal connection, bad battery, charging system problem, excessive current draw. Start by inspecting the battery terminal connections and having your battery tested. Then go from there.
The following link speaks to the proper way to test a battery. Too, it talks about the charging system and parasitic load.
CAR BATTERY FREQUENTLY ASKED QUESTIONS
Also the following thread contains some excellent information on testing for excessive current drain. (See Bill Curlee's replies in this thread.)
battery drain possibly?
Old Oct 12, 2006 | 08:39 PM
bayarea's Avatar
bayarea
the battery cables are fine and everything looks fine. I read the thread in the link, but I still dont know how to stop the excessive draw. what else should I do.
Old Oct 12, 2006 | 09:49 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What is the actual current draw of the electrical system when the PCM and BCM are in the sleep mode??
You need to measure this value and post it. Obtain a digital volt meter that can measure current (up to 10 amps) and place it in SERIES between the negative battery cable and the negative battery terminal.
After the car powers down and sits undisturbed for approx 2-3 minutes (with ALL power consuming devices secured ie radar detectors, interior lights, trunk lights, "HOOD LIGHT" ect) the amp meter should provide you the sleep mode current draw.
Please post that value.
BC
Old Oct 12, 2006 | 11:31 PM
bayarea's Avatar
bayarea
BC
ok Bill I will go get 1 at radio shack 2morrow and c wut happens
To why is my battery going dead??
