Maintainance Besides Oil Changing
Old Sep 16, 2001 | 10:37 PM
VetteOnSHINE's Avatar
VetteOnSHINE
Default Maintainance Besides Oil Changing
I always have had my oil changed every 3,000 or so miles, but am thinking I should also have other maintainance work done. I have 26,500 miles on my ride. What does everyone else here do?
Old Sep 16, 2001 | 11:25 PM
TLewis4095's Avatar
TLewis4095
Default Re: Maintainance Besides Oil Changing (VetteOnSHINE)
Trany fluid & filter every 30-35k, look at brake pads..rotors feel warped at all? if so turn them. Plugs 25-30k (some say longer) Plug wires break down w/heat & time...25-50k, Of course air filter inspection every oil change. Fuel injectors cleaned 25-50k ? Differential lube change 50K, Power sterring fluid flush & fill 35-50k (saves on rack wear). Always inspect all seals for leaks & seepage. Engine coolant every 35-50k or 3 years. Probably more I'm not thinking of right now..serpintine belt? I have put 150k to 250k on several vehicals & have NEVER had engine or tranny problems with this regime. :cool:
