Bulb replacement, help!
Old Oct 14, 2006 | 01:50 AM
SSBob's Avatar
SSBob
Default Bulb replacement, help!
As someone who has installed engines, trannies, brakes, etc., it pains me to post this, but I'm at my wits' end. About a week ago the RF turn signal bulb went out on my 99 FRC. I bought a replacement and have gone nuts trying to access the burned-out bulb and socket. I have tried reaching through the headlight opening with the lights raised. I have tried taking the inner fender liner loose. I did a search here and read about a rubber access panel in the fenderwell. My car does not have it. It has brake ducts that run from the front valence and pass through the front wheelwells, precluding access in that manner. The infernal GM manual, which might be useful as toilet paper if it weren't laminated, recommends removing the 'fascia release bolts' to access these bulbs, but doesn't bother mentioning where these bolts are and, of course, includes no diagram. I feel like a total moron at this point, but can someone help me crack the code or perhaps direct me to a diagram?
Thanks!
Old Oct 14, 2006 | 01:53 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Turn on headlights and back the switch off 1 position....or manually crank the light up. Remove the 3 screws holding the black bezel. Reach down and twist and remove the socket....remove and replace bulb....
Thats all
Old Oct 14, 2006 | 02:04 AM
SSBob's Avatar
SSBob
Thats all
Thanks for the quick reply, but don't those instructions apply to the headlight bulbs? This is the RF turn signal bulb that I can't seem to get to...
Old Oct 14, 2006 | 05:31 AM
DeeGee's Avatar
DeeGee
Reach down beyond the headlight to the parking light DRL cluster. Its a squeeze
I'm with pewter99
You'll get three suggestions
Go in through the brake ducts - not easy with a Z06 or if you have screens
Go in through the bottom by taking out the bottom panel; its about 5 screws to get the panel off
The one that works for me is:
Turn on the headlights and back off one position to kill the lights.
Unscrew the 3 small screws on the black plastic housing around the headlight. Gently pull the housing clear. Reach down around the headlight unit and release the bulb holder. It unscrews counter clockwise but it has a plastic clip which you need to squeeze to release it. Change the bulb. Reseat the bulb holder and turn until it clicks back in place. Put the plastic housing back in place making sure to locate the small plastic tab in the bracket on the headlamp cover. Replace the 3 screws and close the lights.
10 minute job.
The bulb is a 4157NA
Old Oct 14, 2006 | 09:51 AM
SSBob's Avatar
SSBob
Ah, OK. Now I understand about the housing removal. It didn't seem to make sense to me last night. That's what I get for posting a question in the middle of the night!
Thank you for the replies.
Old Oct 14, 2006 | 11:46 AM
dwarmenzerk's Avatar
dwarmenzerk
the other way to do it is to take the front fascia off.. A buddy and i did it in about an hour or so.
I decided to take it off for a few reasons, 1 was because i have very large meat hooks, i wanted to take my foglight housings off and wanted to check the wireing on the turn signal socket..
it went back on in about 15 - 20 mins..
Old Oct 14, 2006 | 05:23 PM
SSBob's Avatar
SSBob
Wow, what a difference removing that black cover around the headlight makes...like the man said, ten minute job. What did we dobefor the Net and forums like this? Thanks again, one and alll.
Old Oct 15, 2006 | 03:09 PM
dwarmenzerk
we would yell, scream, curse, throw things, break things, cry and then bring it to the dealership
Old Oct 15, 2006 | 04:02 PM
6xVETTE's Avatar
6xVETTE
Default bulb
"it pains me to post this"
"What did we dobefor the Net and forums like this? "
I just had to search the forums for instructions on how to change a turn light bulb myself...i feel ya
Thanks for the info guys.
Old Oct 15, 2006 | 07:07 PM
tommybilt's Avatar
tommybilt
I was doing some work on my turn signal circuits to support LEDs and found if you remove the headlight assembly you can get all kinds of room to the DRLs. 3 nuts and 2 bolts after you remove the black bezel and the cover that is attached to the housing. REAL REAL easy.
Old Oct 15, 2006 | 07:21 PM
TEXHAWK0's Avatar
TEXHAWK0
Unless I feel the urge to change out bulbs on the side of the highway, I still find it less hassle to just zip out the 5 or 6 screws that hold the lower access panel in place between the left and right spoiler and the front wheel wells. Then I have enough room to easily remove and replace the bulbs. I recently replaced the lens assemblies because mine had cracked, and there is enough clearance to easily remove the whole assembly through the access panel.
Old Oct 15, 2006 | 09:42 PM
vette747's Avatar
vette747
I'm 100% with TEXHAWK0.
From shop manual:
1- Jack the front of the car.
2- Remove the font fascia lower closeout panel. Small (if I recall 6 x 10 inches) piece of plastic under the front fascia at the left and right corner.
3- Release the brake caliper cooling duct from the front fascia, then reposition the duct. You pull the brake duct and move it so you have access to the lamp assembly.
4- Remove the appropriate socket from the lamp assembly.
5- Remove the bulb from the socket.
To remove the turn lamp assembly: Just remove One 10 mm screw, a spring and the small screw on the assembly.
Old Nov 6, 2006 | 04:05 PM
Vetterable's Avatar
Vetterable
Thanks for the post. I was just about to remove the front facia & thought - there has got to be an easier way. This worked for me:
Don't forget to open the hood after you remove the plastic housing - unless you have really skinny arms.
10 minutes done.
Old Nov 6, 2006 | 04:38 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
If you go in through the headlight. you can also make yourself more arm room by unscrewing the hood bumpstop that's fastened to the front of the hood hinge.
Old Nov 19, 2006 | 06:58 PM
Kebrock's Avatar
Kebrock
St. Jude Donor '11
What kind of screws are those?
Old Nov 28, 2006 | 10:44 PM
acossey's Avatar
acossey
Default Thanks
Thanks all. One detail! open the hood!
Old Dec 5, 2006 | 10:21 AM
beav626's Avatar
beav626
I just did mine and it took a while to find out that the bulb is under the fixture...
Once I got that it was a breeze
To Bulb replacement, help!
Old Dec 5, 2006 | 03:22 PM
chevyvette1's Avatar
chevyvette1
Default The easiest way for me
I see you changed yours, and I've posted these pics before, but here you go, this might help someone in the future, this literally takes about 1 or 2 minutes after you have done it once, there is a tab, as mentioned that you push in while turning, it's easy. You can tell by my light I've had a few bulbs that actually exploded, getting the new clear lights later this year
Old Dec 5, 2006 | 06:07 PM
tsts's Avatar
tsts
Chevyvette1,
That is the easiest way and only takes a couple of minutes as you say, someone showed it to me when they replaced a bulb for me. Only problem is my forarm is too thick to get in there and reach the bulb.
Old Dec 7, 2006 | 10:29 AM
chevyvette1
It's really tight for me as well, I thought I was really stuck one time , that would have been funny, hand stuck in my car
