IAC steps when Datalogging
Old Oct 15, 2006 | 12:05 PM
SCannon's Avatar
SCannon
Default IAC steps when Datalogging
When data logging, should your IAC steps ever move? When my tuner was data logging may car he said under IAC every number sat at 149 the entire time. The IAC park position is set at 149. It is a LS2 TB with a plug and play harness.
Old Oct 15, 2006 | 03:32 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Scan "DESIAC".........not "IAC".
Old Oct 15, 2006 | 05:01 PM
SCannon's Avatar
SCannon
I dont understand? The tuner had his laptop running showing 100 different parameters. All of the parameters for Idle said 149. Is that a different parameter that will move?
Old Oct 15, 2006 | 08:19 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
C5s don't have an IAC valve. The "electronic throttle control" (ETC) controls the idle air. To monitor the steps of the ETC:
EFILive scanner -> "DESIAC" is the PID to use.
HP Tuners scanner -> "IAC Desired Position" is the PID to use.
Hope this helps some.
To IAC steps when Datalogging
