LS1 98 Camaro Engine Block
Old Oct 16, 2006 | 08:39 AM
Brad@RevXtremeAutoSports's Avatar
Default LS1 98 Camaro Engine Block
Is it exactly the same as the vette Ls1?
99% sure it is, but want to be 100% sure before I buy it.
Sorry for the dumb question.
TIA
Old Oct 16, 2006 | 12:07 PM
Face's Avatar
Face
It should be, but it's not the most desirable of block years.
Old Oct 16, 2006 | 04:38 PM
would you be kind enough to elaborate?? my vert is 98. TIA
Old Oct 16, 2006 | 05:45 PM
Face's Avatar
Face
The wall material is thinner in the older blocks. Don't plan on overboring without replacing sleaves.
Old Oct 16, 2006 | 07:16 PM
msuc5vette's Avatar
msuc5vette
TIA
If it matters I believe the oil pans are different.
Old Oct 16, 2006 | 10:13 PM
what year block then is good for going larger on a rebuild?
thanks
Old Oct 16, 2006 | 10:21 PM
SLPRC5's Avatar
SLPRC5
Are you getting it for real cheap? If not, pick up a LS6 or put that money in your present LS1. Unless your engine is shot... my .02c
Old Oct 17, 2006 | 12:53 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Old Oct 17, 2006 | 08:37 AM
the block went for 375 on flea bay. I want to build a seperate block so i can do it myself and still keep the car on the road for as long as possible. thanks for the replys
To LS1 98 Camaro Engine Block
