running warm while cruising...
Old Oct 17, 2006 | 06:59 AM
Jstyle's Avatar
Jstyle
Default running warm while cruising...
Ok here is my issue. I changed my tstat 2 weeks ago since then it runs warm. Not hot but warm and this is the weird part. Now it will run at around 199-208 sitting stopped in traffic. It runs 214-219 while cruising 70 on the highway. How is that even possible?
Old Oct 17, 2006 | 10:04 AM
Jstyle's Avatar
Jstyle
Let me follow up by saying one fan is set to 170 and the other 190. There is a 180 thermo in there.
Old Oct 17, 2006 | 10:13 AM
LinearX's Avatar
LinearX
Sounds like an airflow problem while cruising. Did you bleed the system to get the potential air bubble out?
One thing to check for air flow is between the radiator and A/C condensor. Leaves, grass, trash, etc. all have a way of getting lodged up in there. That would certainly cause airflow problems. Have you also verified that both of your fans are working? I had a dead low speed fan motor that I replaced when I put my new radiator in.
Old Oct 17, 2006 | 12:17 PM
Jstyle's Avatar
Jstyle
Both seem to be working and airflow seems great because the fans are on...
To running warm while cruising...
