Need Spark Plug Info For C5
Old Oct 17, 2006 | 08:28 PM
Exterminator's Avatar
Exterminator
Default Need Spark Plug Info For C5
My buddy needs some info please. For a 2000 C5 how long do the spark plugs generally last? The car doesn't burn any oil and is not run hard at all.
Thanks in advance.
Robin
Old Oct 18, 2006 | 01:51 AM
David426's Avatar
David426
100,000 miles.. This is straight out of the owners manual
Old Oct 18, 2006 | 07:16 AM
GUSTO14's Avatar
GUSTO14
Depending of course on how the Corvette is used, I think most will tell you that you'll notice a difference if you change them with 40k on 'em... some will do it even sooner.
Good luck... GUSTO
Old Oct 18, 2006 | 12:34 PM
99 vett babycar's Avatar
99 vett babycar
changed mine at 40K and could not feel any difference. But it made ME feel better.
Old Oct 18, 2006 | 12:37 PM
Exterminator
Thanks guys, this is about what I would have guessed. I really appreciate the confirming feedback.
Old Oct 18, 2006 | 01:28 PM
EStreeter's Avatar
EStreeter
Platinum and Iridium spark plugs last a long time (100k easy) but if your friend is only driving about 12 - 15 k per year, you don't want to leave the plugs in the head for 4 - 5 years. They may sieze in the aluminum heads.
Even if the plugs don't require changing because of their condition they should be removed more often than every 100,000 miles. And, if you are going to go through the trouble of removing them then why not install new plugs.
Many people have said that they switched from the Platinum or Iridium plugs to NGK TR55 V Power. They last about 20,000 miles but then you would want to change them at that interval anyway. Plus you would save a lot of $$$ if you DIY.
Old Oct 19, 2006 | 07:57 AM
6Speeder's Avatar
6Speeder
Don't leave them in that long. I pulled one to check it after 15,000 miles, found the platinum "puck" on the end of the electrode was gone. Not only was the gap huge with it gone, but the metal puck hadda go through the engine, hopefully without damaging a piston or valve. I pulled the rest, 6 of 8 had MIA pucks. I put in NGK TR-55's.
Old Oct 19, 2006 | 08:31 AM
The Big Guy's Avatar
The Big Guy
St. Jude Donor '12-'13-'14
99 mm6 coupe 79,000 miles original owner. Changed out original plugs at 60,000 miles with A/C 41 - 985 Iridium's. All pucks were in place. Plugs all looked like new. New plug gap spec changed from .060 to .040. I have not noticed any change whatsoever in any catagory of performance/ idle,etc. I changed them so as to have the latest plugs designed for the LS - 1. That's my 2 CTS. Good Luck !
Old Oct 19, 2006 | 12:54 PM
Exterminator
That's a frightening thought.
Old Oct 19, 2006 | 01:12 PM
Exterminator
Thanks this is good info. So it sounds like the spark plug specs have changed since the year 2000?
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
That's why I changed mine out before they had a chance to blow off. My car probably 1800-2000 miles on it at the time. I put in Bosch platinum +4s. A lot of people don't care for Bosch, but my car runs fine.
Old Oct 19, 2006 | 02:23 PM
VetteDrmr's Avatar
VetteDrmr
Changed out mine after 100K miles (I bought the car with 90K). All the pucks were there ('00 FRC), car had been autocrossed and tracked.
I'm with you on the plugs getting tight (wouldn't go so far as to say "siezed"). Put a drop of oil on the threads (not antisieze, that can ground out the plug if it gets on the electrode) and you won't have that problem in the future.
Performance? You'll notice an immediate improvement, which will go away very shortly as the plugs break in.
HTH, and have a good one,
Mike
EDIT: BTW, I changed to NGK TR-55s (copper) at 100K miles, still going strong!
To Need Spark Plug Info For C5
