seat belt stuck
Old Sep 18, 2001 | 07:26 AM
abraham's Avatar
abraham
Default seat belt stuck
my passenger side seat belt is stuck(wont go down or out) it just seems to lock up. anyone had this problem or know how to fix it?
Old Sep 18, 2001 | 08:13 AM
NastyC5's Avatar
NastyC5
Default Re: seat belt stuck (abraham)
I had that problem once with my 99 :mad Pull it out a little by little. Be patient it will come out. Then carefully let it retract.
good luck :chevy
Old Sep 18, 2001 | 08:32 AM
SEAMOORE's Avatar
SEAMOORE
There is a recall on this - check w/ your dealer.
Old Sep 18, 2001 | 12:09 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
you should have received a recall... it takes about 30 minutes.. to do the fix.. call first to make an apointment.. they need to the parts intock.. it is just a plastic guide that is put inside the retractor..
Old Sep 18, 2001 | 02:40 PM
1999 White C5 Coupe's Avatar
1999 White C5 Coupe
This happened to my 1999 C5 coupe (passsenger side) several times before the recall campaign.
Remove the sill trim (pull up - held by several clips) and then untangle the belt material.
Get to your dealer to have the parts installed for the seatbelt recall campaign (a small clip that is placed inside the trim panel to keep the belt from bunching up.)
Isn't it amazing that Chevrolet couldn't make a simple seat belt that won't jam, then it took them several years to issue a recall?
Old Sep 18, 2001 | 05:24 PM
abraham's Avatar
abraham
Default Re: seat belt stuck (1999 White C5 Coupe)
thanks all!
To seat belt stuck
