lowering the front
Old Oct 22, 2006 | 05:37 PM
griffgoody's Avatar
griffgoody
Default lowering the front
I've read the post about lowering the rear. Is lowering the front that easy as turning a nut. Also, when you lower the front do you need to have the front end lined back up. Thks John
Old Oct 22, 2006 | 06:01 PM
FrogmanDave's Avatar
FrogmanDave
Yes and yes. Same for the front. Check out the tech section there's a how to there. Now if you want to go lower (like I did with my Z06) there's bushing cutting involved and longer bolts out back if you want to go really low. Just spinning the bolts will usually suffice on a vert or coupe.
Dave
