proper torque 4 the bolts on upper control arm
Old Oct 23, 2006 | 07:21 AM
prochargedz's Avatar
prochargedz
Default proper torque 4 the bolts on upper control arm
thanks, the manual says 80 lbs of torque.....we snapped two bolts at this level. is this correct? thanks. kvn
Old Oct 23, 2006 | 08:34 AM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
According to the service manual.
48 ft lbs.. not 80.
The only thing in the whole spec table that is 80 ft lbs is the cradle mounting nuts at 81.
Hope that helps.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Oct 23, 2006 | 08:38 AM
David A's Avatar
David A
This is from the manual for my '03:
1) Install the upper control arm to the vehicle.
Important: The upper control arm shims will have an effect on the camber and the caster. Make sure to use an equal thickness of shims on both sides of each individual upper control arm bushing.
2) Install the upper control arm shims.
3) Install the upper control arm mounting bolts to the upper control arm and frame rail.
Tighten the upper control arm mounting bolts to 65 N·m (48 lb ft).
4) Install the upper ball joint stud into the upper control arm. It will be necessary to use an allen wrench to keep the ball joint stud from spinning while tightening the ball joint stud nut.
Tighten the upper control arm ball joint stud nut to 20 N·m (15 lb ft) to seat the ball joint stud.
Check the ball joint nut for a minimum final torque of 50 N·m (37 lb ft).
5) Connect the ESC sensor link.
6) Remove the jackstand.
7) Install the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
8) Lower the vehicle.
Old Oct 23, 2006 | 12:14 PM
JonLT4CE's Avatar
JonLT4CE
The rear uppers are 81 - not the fronts. That's probably why.
Jon
To proper torque 4 the bolts on upper control arm
