2000 C5 ABS/Traction problem
Old Oct 23, 2006 | 07:32 AM
CMYC4GO's Avatar
CMYC4GO
Default 2000 C5 ABS/Traction problem
My 2000 C5 is giving me intermittent error messages regarding ABS and Traction Control System. This usually happens when I hit a hard bump. Whatever is wrong with it, I don't think it's too serious, but it IS aggrivating. I pulled the Codes, and came up with: C1243
I cleaned the ground connection up by the battery, and am going to continue to clean various grounds on the body this morning. Any tips/ideas will be greatly apppreciated. Thanks!
Old Oct 23, 2006 | 07:51 AM
DeeGee's Avatar
DeeGee
C1243 is "BPMV Pump Motor Stalled".
Grounds are worth checking, particularly if its occurring over a bump, but with that code it could be a bigger problem. Here's hoping its the easy fix
Old Oct 29, 2006 | 09:12 PM
rlbock's Avatar
rlbock
Default ABS and Traction control issues
My 2000 had both lights on for about 4 months until I was able to purchase a new EBCM module for $340.00 from a dealer and I installed it in about 3 hours and it solved all of my problems. Let me know if I can be of any further service.
To 2000 C5 ABS/Traction problem
