How To Remove Stripped Diff Drain Plug?
Old Oct 25, 2006 | 04:53 PM
UVETTYA's Avatar
UVETTYA
Default How To Remove Stripped Diff Drain Plug?
Anyone have experience removing the Diff drain plug when the socket head is rounded out? TIA.
Old Oct 25, 2006 | 05:36 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
drill through it and use big easyout. Keep vacuum to suck drilling material from going in the diff. Just my guess on a solution. May be make flat plate 1/8" steel stock used like a big screw driver blade and tap it in on a diagonal then turn with a big adjustable.
Old Oct 25, 2006 | 05:44 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Vice grips
Old Oct 25, 2006 | 05:51 PM
DaveP's Avatar
DaveP
weld a piece of hex key-allen wrench to/in it, use socket on allen wrench to remove.
Old Oct 26, 2006 | 01:13 AM
az57chevy's Avatar
az57chevy
Sears sells a socket set that has a cutting helical edge on the inside to bite into a rounded bolt. Not sure what they are officially called. In the 'old" days you could use a file to create a slot in the head and use a large screwdriver to help turn it with a box wrench shoved onto the stripped head. Finally a little liquid wrench on the bolt might help loosen it since it sounds like it is "tight"
Old Oct 26, 2006 | 09:38 AM
99 vett babycar's Avatar
99 vett babycar
pipe wrench
Old Oct 26, 2006 | 11:20 AM
kromberg's Avatar
kromberg
Originally Posted by mvvette97
Vice grips
or grind two new flat edges parallel to one another. Me being lazy, I go with the first solution
Keith
Old Oct 26, 2006 | 01:05 PM
N0TDADYS_98's Avatar
N0TDADYS_98
everything above will probably work..
probably help if we had a picture or two to see what we are dealing with..
Old Oct 26, 2006 | 02:22 PM
tabbruzz's Avatar
tabbruzz
Vice grips
To How To Remove Stripped Diff Drain Plug?
