Torque Specs Please!
Old Oct 25, 2006 | 05:36 PM
happa's Avatar
happa
Default Torque Specs Please!
Can someone give me the torque specs on the oil pan bolts? The ones at the rear. Thank you!
Old Oct 25, 2006 | 06:37 PM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
the two really long ones go to something like 13ftlbs
Old Oct 25, 2006 | 06:49 PM
happa's Avatar
happa
Thank You very much!
Old Oct 25, 2006 | 09:50 PM
jrprich's Avatar
jrprich
Fr Susp Brakes
Xmember Mounting Nuts (Use New Nuts) 110 N·m 81 lb ft
Lower Control Arm Ball Joint Stud Nut (1st Pass) 20 N·m 15 lb ft Brake Caliper Bleed Screw 12 N·m 106 lb in
Lower Control Arm Ball Joint Stud Nut (2nd Pass) 210 deg Brake Caliper Guide Pin Bolt 31 N·m 23 lb ft
Lower Control Arm Ball Joint Stud Nut (Final Pass) 70 N·m 52 lb ft Brake Caliper Inlet Fitting Bolt 40 N·m 30 lb ft
Lower Control Arm Mounting Bolt Nuts 170 N·m 125 lb ft Fr Brake Caliper Mounting Bracket Bolt 175 N·m 125 lb ft
Shock Absorber Lower Mounting Nuts 28 N·m 21 lb ft Rr Brake Caliper Mounting Bracket Bolt 175 N·m 125 lb ft
Shock Absorber Upr Mounting Nut 26 N·m 19 lb ft
Stabilizer Shaft Insulator Clamp Bolts 58 N·m 43 lb ft Engine Nm Ft Lb in-lb
Stabilizer Shaft Link Nuts 72 N·m 53 lb ft AIR Pipe-to-Exh Man Bolts 20 15 --
Steering Linkage Outer Tie Rod End Stud Nut (1st Pass) 20 N·m 15 lb ft AIR Rt Side Pipe Bracket-to-head Bolt 50 37 --
Steering Linkage Outer Tie Rod End Stud Nut (2nd Pass)160 deg Camshaft Retainer Bolts 25 18 --
Steering Linkage Outer Tie Rod End Stud Nut (Final Pass)45 N·m 33 lb ft Camshaft Sensor Bolt 25 18 --
Steering Linkage Tie Rod End Jam Nut 60 N·m 44 lb ft Camshaft Sprocket Bolts 35 26 --
Transverse Spring Retainer Bolts (Use New Bolts) 62 N·m 46 lb ft Connecting Rod Bolts (1st Pass) 20 15 --
Upr Control Arm Ball Joint Stud Nut (1st Pass) 20 N·m 15 lb ft Connecting Rod Bolts (fin Pass) 60 deg 97'-00'
Upr Control Arm Ball Joint Stud Nut (2nd Pass) 250 deg Connecting Rod Bolts (fin Pass) 75 deg 01'-
Upr Control Arm Ball Joint Stud Nut (Final Pass) 55 N·m 41 lb ft Coolant Temperature Gauge Sensor 20 15 --
Upr Control Arm Mounting Bolts 65 N·m 48 lb ft Crank Balancer Bolt (Installation Pass-to Ensure t3h3e0 Balanc2e4r0 is Com--pletely Installed)
Wheel Hub/Bearing Mounting Bolts 130 N·m 96 lb ft Crank Balancer Bolt (1st Pass-Loosen the Bolt afte5r0 the Inst3a7llation P--*** and Re-tighten Crank Balancer Bolt (fin Pass) 140 deg
Crank Bearing Cap Bolts (Inner Bolts-1st Pass in S2e0quence)15 --
Rr Susp Crank Bearing Cap Bolts (Inner Bolts-fin Pass in8 S0e dqeugence)
Lower Control Arm (Fr) Cam Bolt Nut 145 N·m 107 lb ft Crank Bearing Cap Side Bolts 25 18 --
Lower Control Arm (Rr) Cam Bolt Nut 95 N·m 70 lb ft Crank Bearing Cap Studs (Outer Studs-1st Pass in2 0Sequenc1e5) --
Lower Control Arm Ball Joint Stud Nut (1st Pass) 20 N·m 15 lb ft Crank Bearing Cap Studs (Outer Studs-fin Pass 5in3 Sdegquence)
Lower Control Arm Ball Joint Stud Nut (2nd Pass) 3 ½ flats Crank Oil Deflector Nuts 25 18 --
Lower Control Arm Ball Joint Stud Nut (Final Pass) 70 N·m 52 lb ft Crank Position Sensor Bolt 25 18 --
Outer Tie Rod End Stud Nut (1st Pass) 20 N·m 15 lb ft head Bolts (1st Pass all M11 Bolts in Sequence) 30 22 --
Outer Tie Rod End Stud Nut (2nd Pass) 160 deg head Bolts (2nd Pass all M11 Bolts in Sequence)90 deg
Outer Tie Rod End Stud Nut (Final Pass) 45 N·m 33 lb ft head Bolts (fin Pass all M11 Bolts in Sequence -9 E0x dcelugding the Medium Length Bolts Rr Xmember Mounting Nuts (Use New Nuts) 110 N·m 81 lb ft head Bolts (fin Pass M11 Medium Length Bolts a5t0 F dr eagnd Rr of Each head in Sequence)
Rr Drive Axle Spindle Nut 160 N·m 118 lb ft head Bolts (M8 Inner Bolts in Sequence) 30 22 --
Rr Susp Adjustment Link to Xmember Nut 60 N·m 44 lb ft head Coolant Plug 20 15 --
Shock Absorber Lower Mounting Bolt 220 N·m 162 lb ft head Core Hole Plug 20 15 --
Shock Absorber Upr Mounting Bolts 29.5 N·m 22 lb ft Drive Belt Idler Pulley Bolt 50 37 --
Stabilizer Shaft Insulator (Lower) Clamp Nut 95 N·m 70 lb ft Drive Belt Tensioner Bolts 50 37 --
Stabilizer Shaft Insulator (Upr) Clamp Bolt 65 N·m 49 lb ft Engine Block Coolant Drain Plugs 60 44 --
Stabilizer Shaft Link Nuts 72 N·m 53 lb ft Engine Block Heater 40 30 --
Tie Rod End Jam Nut 60 N·m 44 lb ft Engine Block Oil Gallery Plugs 60 44 --
Transverse Spring Mounting Bracket Bolts 62 N·m 46 lb ft Engine Coolant Air Bleed Pipe Bolts 12 -- 106
Upr Control Arm Ball Joint Stud Nut (1st Pass) 20 N·m 15 lb ft Engine Flywheel Bolts (1st Pass) 20 15 --
Upr Control Arm Ball Joint Stud Nut (2nd Pass) 250 deg Engine Flywheel Bolts (2nd Pass) 50 37 --
Upr Control Arm Ball Joint Stud Nut (Final Pass) 55 N·m 41 lb ft Engine Flywheel Bolts (fin Pass) 100 74 --
Upr Control Arm Mounting Bolt 110 N·m 81 lb ft Engine Flywheel Hub Collar Bolt (auto trans) 130 96 --
Wheel Hub Mounting Bolts 130 N·m 96 lb ft Engine Fr Cover Bolts 25 18 --
Engine Mount Bracket-to-Engine Block Bolts 50 37 --
Trans Engine Rr Cover Bolts 25 18 --
Bearing Hsng Assm to Coupling Bolts 70 N·m 52 lb ft Engine Service Lift Bracket M10 Bolts 50 37 --
Bearing Hsng Assm to Driveline sup Tube Bolts 65 N·m 48 lb ft Engine Service Lift Bracket M8 Bolt 25 18 --
Clutch Actuator Cylinder Mounting Bolts 12 N·m 106 lb in Engine Valley Cover Bolts 25 18 --
Coupling to Propeller Shaft Bolts 70 N·m 52 lb ft Exh Man Bolts (1st Pass) 15 11 --
Driveline Tunnel Closeout Panel Bolts 10 N·m 89 lb in Exh Man Bolts (fin Pass) 25 18 --
Driveline sup Assm to Engine Flywheel Hsng Bolts 50 N·m 37 lb ft Fuel Injection Fuel Rail Bolts 10 -- 89
EBTCM LH Mounting Bracket Mounting Bolts 50 N·m 37 lb ft Generator and Power Steering Pump Bracket Bolts50 37 --
Flexplate to Flexplate Spindle Bolts 50 N·m 37 lb ft Generator Rr Bracket Bolts 50 37 --
Hub to Flexplate Spindle Bolt (Automatic trans) 50 N·m 37 lb ft Ground Strap-to-LH head Bolt 32 23 --
Input Shaft Bearing Positioning Bolts 35 N·m 26 lb ft Ground Strap-to-LH Frame Rail Bolt 10 -- 89
Input Shaft to Coupling Bolts 70 N·m 52 lb ft Ignition Coil Bolts 12 -- 106
Negative Battery Cable Bolt 15 N·m 11 lb ft Ignition Coil Wire Harness Connector Bolts 12 -- 106
Output Flange Bolt 50 N·m 37 lb ft Int Man Bolts (1st Pass in Sequence) 5 -- 44
Propeller Shaft Hub Clamp Bolt 130 N·m 96 lb ft Int Man Bolts (fin Pass in Sequence) 10 -- 89
Rr Exhaust Hanger Mounting Bolts 50 N·m 37 lb ft Knock Sensors 20 15 --
Rr Shock Absorber Lower Mounting Bolt 220 N·m 162 lb ft Oil Filter 30 22 --
Rr Susp Xmember Mounting Nuts 110 N·m 81 lb ft Oil Filter Fitting 55 40 --
Shift Control Mounting Bolts 30 N·m 22 lb ft Oil Level Indicator Tube Bolt 16 12 --
Shift Control Closeout Boot Retaining Nuts 12 N·m 106 lb in Oil Level Sensor 13 -- 115
Transaxle Mount Bracket to Differential Bolts 50 N·m 37 lb ft Oil Pan Baffle Bolts 12 -- 106
Transaxle Mount to Rr Susp Xmember Nuts 50 N·m 37 lb ft Oil Pan Cover Bolt (Left Side) 12 -- 106
trans to Driveline sup Assm Bolts/Studs 50 N·m 37 lb ft Oil Pan Cover Bolt (Rt Side) 12 -- 106
trans Oil Cooler Rr Pipe Fr Fittings to Junction Fittings at E2n7g Nin·em Flyw20h elbe lf tHsngOil Pan Cover Bolts 12 -- 106
trans Oil Cooler Rr Pipe Rr Fittings to trans Fittings 40 N·m 30 lb ft Oil Pan Drain Plug 25 18 --
trans Oil Cooler Rr Pipe Fr and Rr Retaining Clamp Bolts 12 N·m 106 lb in Oil Pan M8 Bolts (Oil Pan-to-Engine Block and Oil 2P5an-to-Fr1 C8over) --
trans Shift Control Cable Bracket Retaining Nuts 20 N·m 15 lb ft Oil Pan M6 Bolts (Oil Pan-to-Rr Cover) 12 -- 106
trans Shift Rod Clamp Bolt 30 N·m 22 lb ft Oil Pressure Sensor 20 15 --
trans Wiring Harness to LH trans Case Retaining Bolt 2.5 N·m 22 lb in Oil Pump-to-Engine Block Bolts 25 18 --
Rr Drive Shaft Spindle Nut 160 N·m 118 lb ft Oil Pump Cover Bolts 12 -- 106
Diff Oil Pump Relief Valve Plug 12 -- 106
Differential Case Bolts 55 N·m 41 lb ft Oil Pump Screen Nuts 25 18 --
Differential-to-trans Bolts and Nuts 50 N·m 37 lb ft Oil Pump Screen-to-Oil Pump Bolt 12 -- 106
Drain Plug 35 N·m 26 lb ft Oil Temperature Sensor 20 15 --
Driveline sup Assm-to-Engine Flywheel Hsng Bolts 50 N·m 37 lb ft Oxygen Sensor 42 31 --
Electronic Brake and Traction Control Module (EBTCM) LH50 M No·umnting3 7B lrba cftket BoPlotswer Steering Pump Bolts 25 18 --
Fill Plug 35 N·m 26 lb ft Power Steering Reservoir Bracket Bolt 50 37 --
Left Side Cover Bolts 25 N·m 18 lb ft Spark Plugs (head-New) 20 15 --
Negative Battery Cable Bolt 15 N·m 11 lb ft Spark Plugs (head-all Subsequent Installations) 15 11 --
Pinion Hsng/Cage Bolts 25 N·m 18 lb ft Starter Motor Bolts 50 37 --
Pinion Nut 500 N·m 370 lb ft Throttle Body Bolt 12 -- 106
Propeller Input Shaft Bearing Positioning Bolts 35 N·m 26 lb ft Valve Lifter Guide Bolt 12 -- 106
Propeller Shaft Hub Clamp Bolt 130 N·m 96 lb ft Valve Rocker Arm Bolts 30 22 --
Rr Cover Bolts and Stud 10 N·m 89 lb in Valve Rocker Arm Cover Bolts 12 -- 106
Rr Shock Absorber Lower Mounting Bolt 220 N·m 162 lb ft Water Inlet Housing Bolts 15 11 --
Rr Susp Xmember Mounting Nuts 110 N·m 81 lb ft Water Pump Bolts (1st Pass) 15 11 --
Right Side Cover Bolts 25 N·m 18 lb ft Water Pump Bolts (fin Pass) 30 22 --
Ring Gear Bolts 195 N·m 144 lb ft Water Pump Cover Bolts 15 11 --
Shift Control Closeout Boot Retaining Nuts 12 N·m 106 lb in Water Pump Pulley Bolts (1st Pass) 10 -- 89
Shift Control Mounting Bolts 30 N·m 22 lb ft Water Pump Pulley Bolts (fin Pass) 25 18 --
Transaxle Mount Bracket-to-Differential Bolts 50 N·m 37 lb ft Exhaust
Transaxle Mount-to-Bracket Nuts 59 N·m 43 lb ft Exhaust Manifold to Takedown Pipe Bolts 20 N·m 15 lb ft
Transaxle Mount-to-Rr Susp Xmember Nuts 50 N·m 37 lb ft Exhaust Muffler Hanger Frame Nut 16 N·m 12 lb ft
trans Oil Cooler Rr Pipe Fitting-to-Junction Fittings at Engi2n7e NFl·ymwhe2e0l Hlbs nftg Front Exhaust Hanger Bolt 50 N·m 37 lb ft
trans Shift Rod Clamp Bolt 30 N·m 22 lb ft Fuel Tank Shield Bolt 25 N·m 18 lb ft
trans Stud Mount Bolts 10 N·m 89 lb in Fuel Tank Shield Nut 12 N·m 106 lb in
trans Stud-to-Mount 42 N·m 31 lb ft Heated Oxygen Sensor 41 N·m 30 lb ft
trans Wiring Harness-to-LH trans Case Retaining Bolt 2.5 N·m 22 lb in H-Pipe to Rear Pipe bolts 50 N·m 37 lb ft
Vehicle Speed Sensor Bolt 10 N·m 89 lb in Rear Exhaust Hanger Bolt 50 N·m 37 lb ft
Clutch Rear Stabilizer Shaft Bolt 54 N·m 40 lb ft
Clutch Actuator Cylinder Mounting Bolts 12 N·m 106 lb in H-pipe hanger to bellhousing bolts 50 N·m 37 lb ft
Clutch Pedal Nut 50 N·m 37 lb ft
Clutch Pressure Plate Bolts¹ 63 N·m 47 lb ft
Cruise Release Switch Bracket Retaining Bolts 12 N·m 106 lb in
Engine Flywheel Inspection Cover Retaining Bolts 25 N·m 18 lb ft
Old Oct 25, 2006 | 10:40 PM
happa's Avatar
happa
Thanks man That helped too, but what dies this mean? Oil Pan M6 Bolts (Oil Pan-to-Rr Cover) 12 -- 106 Is that 12 ft lbs/ Thanks
Old Oct 25, 2006 | 10:46 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
that's 12 Newton Meters, metric equivalent
To Torque Specs Please!
