Z06 Spring #'s: Need some help...
Old Oct 25, 2006 | 06:24 PM
mikexxxx's Avatar
mikexxxx
Default Z06 Spring #'s: Need some help...
I recently purchased front & rear springs from an 03 Z and the #'s on the springs don't match the typical FE4 #'s,
My front 22171750
My rear 22188078
Typical numbers for z06 springs are,
- Z06 Front spring: 22178729
- Z06 Rear spring: 22188038
In fact they don't match any spring numbers. Does anybody have an idea as to referencing these to see if they are indeed z06? I believe they are, but I'm curious.
Regards,
Mike
Old Oct 25, 2006 | 07:06 PM
JonLT4CE's Avatar
JonLT4CE
My front 22171750
My rear 22188078
Regards,
Mike
I know that the current part numbers for the Z06 springs are different.
I found this out when I tried to get prices at GMpartsdirect. The old part numbers wouldn't come up because GM changed the numbers.
I'll try to find the before and after numbers.
Old Oct 25, 2006 | 07:28 PM
vettenuts's Avatar
vettenuts
My front 22171750
My rear 22188078
Regards,
Mike
From my 02 parts CD:
22171750 - ???
22188078 - ???
22178729 - FE3, FE4
22188038 - M12, FE4
The top numbers don't show up on Fred Beans either. I did some searching, the rear number you are using appears to be the Liteflex part number (vendor) and is from a FE3, not FE4.
See post #32
More information
Old Oct 26, 2006 | 07:36 PM
mikexxxx's Avatar
mikexxxx
Anybody else?
Old Oct 27, 2006 | 01:04 AM
ChipN's Avatar
ChipN
I purchased a rear Z06 spring from Fred Beans. The part number was 22188038. Since you guys say that you can't find it at Beans' website I checked www.gmpartsdirect.com - found it there.
Old Oct 27, 2006 | 05:49 AM
vettenuts's Avatar
vettenuts
Chip,
Is that the GM part number? It almost sounds like the vendor has his own numbers molded into the spring and then GM puts their own number on it as well.
Old Oct 27, 2006 | 10:14 PM
mikexxxx's Avatar
mikexxxx
In case anybody is interested I checked with Flexlite and the 2 springs I have are z06 springs
Old Oct 28, 2006 | 12:16 AM
ChipN's Avatar
ChipN
Originally Posted by vettenuts
Chip,
Yes, it was the GM part number. I originally found the number on a CF post, then checked Beans and GM parts direct. Once you factored in shipping Beans was about $20 cheaper. But, I used the same part number at both sites.
To Z06 Spring #'s: Need some help...
