How does the computer figure miles per gallon?
Old Oct 25, 2006 | 10:23 PM
Mike04's Avatar
Mike04
Default How does the computer figure miles per gallon?
How does the computer figure the car's actual miles per gallon? Does it actual monitor the amount of fuel flow over distance..... Do after market fuel components/ systems change things
Old Oct 25, 2006 | 11:20 PM
01BoostedZ's Avatar
01BoostedZ
I would be interested in this as well. My computer calculation is way off. It reads 36 MPG when the actual true calculation is 24 MPG.
Old Oct 25, 2006 | 11:24 PM
TYSON1997's Avatar
TYSON1997
From watching what changes it I would guess it uses rpm, tps, and speed, and some constant programmed from the factory that is incapable of correcting for any mods. Use to be 28mpg on highway, now w/ 3:73 and an m-12 It seems to think I get 38mpg at about 70 cruise. More like 25mpg or so.
Old Oct 25, 2006 | 11:50 PM
gpotski's Avatar
gpotski
If you start with a full tank and reset the mpg, you'll get the most accurate reading.
The computer probably calculates from the fuel gauge settings and the odometer. Not a real difficult calculation.
Old Oct 26, 2006 | 12:17 AM
white90conv's Avatar
white90conv
I believe it uses actual miles travelled and the injector pulse width. This is the way it was on the C4 and other cars I have owned. With the number of pulses per second, the pulse width, the capacity of the injectors and the number of injectors, it can do a fairly good job of estimating the fuel flow rate.
If you change injectors, it will use the wrong fuel flow per injector. Mine reads about 8% high and my C4 was 33% high until I replaced the injectors and then it became about 10% low. I think this can all be calibrated in the pcm.
Old Oct 26, 2006 | 08:44 AM
TomT's Avatar
TomT
I would have guessed that there was some kind of flow meter in the fuel line used in connection with the speedo. My '83 El Dorado had this mpg readout and it was very accurate, as is the vette.
Old Oct 26, 2006 | 08:49 AM
Flight Test's Avatar
Flight Test
Cruise-In II Veteran
Ask the guy who wrote the algorithm.
Old Oct 26, 2006 | 09:59 AM
chuckster's Avatar
chuckster
I reprogrammed my IPW (A few % Richer)... So I KNOW my MPG reading is off...
Old Oct 26, 2006 | 11:53 AM
timemender's Avatar
timemender
My stock 2003 LS1 calculates 25MPG highway while it is actually getting 30MPG highway, according to calculations the old fashioned way – Fill-up-to-Fill-up. (I’ve never calculated mileage around town)
With two gas tanks, etc the calculation program has lots of room for error.
Old Oct 26, 2006 | 12:01 PM
kromberg's Avatar
kromberg
And that would be........
Keith
Old Oct 26, 2006 | 12:13 PM
robvuk's Avatar
robvuk
I don't exactly know but I would have to agree with white90conv. I DO know that it has nothing to do with the amount of fuel in the tank. Firstly that would leave far too much room for error. Secondly, the calculations remain the same after you fill up. Injector flow and distance, is the only way to do it. So if you change your rear gear and the odometer remains accurate, so will your mileage. If you change tire diameter without compensating for speedo error, you will then have mileage error. If you put cams, headers or any other bolt-on outside of different capacity injectors, you should remain accurate. The calculation is Miles Per Gallon. So the only thing needed is how many gallons and how many miles. RPM or fuel tank levels have nothing to do with it.
Old Oct 26, 2006 | 12:18 PM
Face's Avatar
Face
I noticed people who upgrade thier injectors, thier calculations are way off. So I'd be willing to bet injector pulse would be one of the factors.
Old Oct 26, 2006 | 12:26 PM
robvuk's Avatar
robvuk
That's probably the only way to accurately calculate the total fuel used. Even expensive fuel flow meters have margins of error. So pulse width makes the most sense. Fuel pressure might affect that somewhat. So that may account for variations in accuracy from car to car. Due to the variations in actual fuel pressure at the injector. That's why any other change besides those that will affect the injectors or speedo will have no consequence. Speedos can be reset but I don't know what you could do about the pulse width calculation. I don't know if there's any such adjustable parameter on a programmer. Even if there was, it would be difficult to figure out how to reset it.
Old Oct 26, 2006 | 12:31 PM
kromberg's Avatar
kromberg
When I upgraded my injectors to SVO 30# for my old 383, my mpg went to 6. I know I have a lead foot, but come on
Keith
Old Oct 26, 2006 | 01:00 PM
C5XTASY's Avatar
C5XTASY
I can vouch for that.
Ed
Old Oct 26, 2006 | 01:52 PM
FRCTony's Avatar
FRCTony
You'd be right. The reason is because the "tuner" did not correct the IFR table. This to me is a sure sign of a bad tune.
Old Oct 26, 2006 | 02:40 PM
Mike04's Avatar
Mike04
A tuner needs to step in and tell us if they change anything as far as injector size.
To How does the computer figure miles per gallon?
Old Oct 26, 2006 | 02:49 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its fuel flow (using injector pulde with "given a known volume of fuel that the injector will flow") verses distance travled.
Turn your DIC to display "Instant MPG" while your doing 60-70 MPH and throw it in to nuteral and coast with the engine at idle. The instant MPG will run up to 99.00 MPG and slowly drop as your speed decreases. The only variables that are changing is speed (tire rotation) and injector pulse width (engine idling at 750 RPM).
BC
Old Oct 26, 2006 | 04:07 PM
ArKay99's Avatar
ArKay99
BC
I think this is how it's figured. You gave the solution by stating the factor as ("injector pulse with "given a known volume of fuel that the injector will flow"") is actually a table. It's the Injector Flow Rate table, and it's calibrated in lbs./hr by MAP or Manifold Air Pressure.
So based on the MAP which is a very close approximation of the load on the engine, it has a lookup value for the actual amount of fuel being used at any time. It then could use that figure coupled with the speed to compute the amount of fuel being used. I think it uses the instant value and caches that, then averages that value continuously over a period of time and samples to determine the average fuel used.
Old Oct 26, 2006 | 04:36 PM
DPG's Avatar
DPG
St. Jude Donor '06
mines pretty accurate, thats all i really care about
