Flameball Installation on Automatic ?? Can it be done ??
Old Sep 19, 2001 | 11:32 AM
Danger Dave's Avatar
Danger Dave
Default Flameball Installation on Automatic ?? Can it be done ??
Several of us C4 auto guy's are looking at buying/installing the Flameball on our cars. Have any C5 auto guy's done this installation? I have sent an email to flameball but no response as of yet. Any help would be great.
Thanks.
Old Sep 19, 2001 | 11:41 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Flameball Installation on Automatic ?? Can it be done ?? (Danger Dave)
yes and I think either BigToe or Sensei Earl has done it, but I think it was BigToe...you basically have to buy 2 *****.....one "regular" aftermarket A4 know to get a piece that comes in the kit, I wanna say it's a shaft.
That new part/shaft allows you use an M6 **** on an A4....hope this helps :cheers:
Old Sep 19, 2001 | 11:49 AM
Danger Dave
Default Re: Flameball Installation on Automatic ?? Can it be done ?? (Mean Green 2000)
Mean Green 2000,I'll send Bigtoe an email.
Any others want to chime in please do with pics if you have them.
Old Sep 19, 2001 | 01:32 PM
C5_PIG's Avatar
C5_PIG
Robsvette installed one himself on his a4. I'm sure he can give more details.
Old Sep 19, 2001 | 06:28 PM
Ram Air Tony's Avatar
Ram Air Tony
Default Re: Flameball Installation on Automatic ?? Can it be done ?? (C5_PIG)
Bigtoe has done it on his A4 C5.......I will report this post to him
thanks
Old Sep 19, 2001 | 06:48 PM
Danger Dave
Default Re: Flameball Installation on Automatic ?? Can it be done ?? (Ram Air Tony)
Thanks.
Old Sep 19, 2001 | 06:52 PM
Untouchable00's Avatar
Untouchable00
Buckmaster gave me the directions yesterday as I inquired about it:
I'll fill in the 2 blanks if you email me (hate to be biased to certain distributors)
I bought the A4 aluminum shift **** kit from (BLANK) and with that kit a "shaft" is included. When you remove the stock "button type" shifter a steel rod is exposed. The "shaft" kit slides over the top of the steel rod that is exposed when you remove the stock "button type" shifter. The Flameball screws onto the top of the "shaft". To light it up, on the bottom of the Flameball is a small "worm hole" where the light bulb/wiring slips into, then you fish the wire down through the leather boot of the shifter underneath to the where the Active Handling is. (BLANK) sells a wiring kit that a monkey could wire......no splicing is required at all and no evasive re-wiring or cutting involved. The kit they have includes "clamps" and you simply put the "clamp" over the wire that you're tapping into and close the "clamp" and it self-taps into the wire. You will know which wires to use with the easy directions they will provide with the kit. How you get to these wires is easy, open you glove box and you will see the edge of the panel where the Active Handling is, it simply pops off very easily with a small screwdriver and you will see all the
wires. I guess all of the above sounds like a lot but it really isn't.
To Flameball Installation on Automatic ?? Can it be done ??
