TPS Questions..I need some help
Old Oct 31, 2006 | 05:55 PM
Barrier's Avatar
Barrier
Default TPS Questions..I need some help
I purchased a set of new Tire Pressure Sensors for my '99 FRC. I am replacing the Chrome rims with Y2K painted versions along with new tires and these pressure sensors. They came with O rings but no washers or nuts. I need to see a parts breakdown to determine if there are 2 O rings per sensor or just one. The O rings are already installed, do they go inside the wheel, then the wheel, washer and nut? Or is there a second O ring mounted outside the wheel then the washer and nut?
A breakdown photo would be great but I cannot find one.
thanks in advance
Barrier
Old Oct 31, 2006 | 07:02 PM
LoneStarFRC's Avatar
LoneStarFRC
One o-ring per sensor. Install the o-ring over the stem, slide the TPM sensor through the hole and install the nut on the outside. Torque to proper value. Use care, the nuts are aluminum.
BTW, TPS is Throttle Position Sensor.
HTH
Old Oct 31, 2006 | 08:27 PM
Barrier's Avatar
Barrier
Thanks LoneStarFRC, Is there a separate Washer or is that what GM calls the O ring?
I found 2 parts numbers. 10268439 for the nuts and 10268439 for the washer. Do those3 numbers sound right?
Barrier
Old Oct 31, 2006 | 08:30 PM
Barrier's Avatar
Barrier
Default Corrected TPM not TPS Problem
I stand corrected.
Barrier
Old Nov 1, 2006 | 07:54 AM
Barrier's Avatar
Barrier
ttt
Old Nov 1, 2006 | 08:03 AM
GUSTO14's Avatar
GUSTO14
entry #5... http://forums.corvetteforum.com/show...ghlight=o+ring
Thank you to MAC5...
GUSTO
Old Nov 1, 2006 | 09:04 AM
Barrier's Avatar
Barrier
Thanks GUSTO.
So the Washer is the O ring.
I just need to get the nuts since the sensor came with the O ring.
Barrier
To TPS Questions..I need some help
