best shocks for 2004 base coupe
Old Nov 3, 2006 | 07:12 AM
VetteDrmr's Avatar
VetteDrmr
Did a search (hint, hint) and came up with the following threads:
http://forums.corvetteforum.com/show...ht=F55+stuffer
Good luck, and have a good one,
Mike
Old Nov 4, 2006 | 11:52 AM
olderguy's Avatar
olderguy
Navigator
Default shock stuffers
guys: after reading yr posts on shock stuffers, i went out and looked under my vette. had a flashlight and there they were. SHOCK STUFFERS for sure. yellow plastic tabs sticking out of the boot of each rear shock. couldnt get under the front to check, but probably still there too. you guys are freaking amazing. i started the post to get new shocks because the ride was so bad. since my car is still under warranty i will be down at the chevy house monday to explain shock stuffers. i cant thank you enought for your ideas.. i will report onthe result monday. thank you again, olderguy
Old Nov 4, 2006 | 06:36 PM
blktie8's Avatar
blktie8
Default Glad it all worked out
Don't let the car out of your sight at the dealership
I had the toneau Painted and they put 108 miles on the car
Just my .02
JOhn
Old Nov 4, 2006 | 06:39 PM
johnnyvettes's Avatar
johnnyvettes
CHICAGO CREW !
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
2000 base coupe 04 z06 I love them also z06 sway bars
Old Nov 4, 2006 | 09:47 PM
VetteDrmr's Avatar
VetteDrmr
Glad it was an easy find! Don't let them keep your baby any longer than necessary (or find a local C5 friend that could help you pull them yourself).
And, if the dealer starts saying something like "those are supposed to be in there", just get your baby and run away!
Have a good one,
Mike
Old Nov 6, 2006 | 01:19 PM
VetteDrmr's Avatar
VetteDrmr
So, did you get the stuffers pulled?
Old Nov 6, 2006 | 01:57 PM
olderguy's Avatar
olderguy
Navigator
yeap, pulled at 8:30 this morning. just in the rear. drives like a new car. i am very pleased. best regards, olderguy
Old Nov 6, 2006 | 04:38 PM
chaase's Avatar
chaase
St. Jude Donor '12
gratz...hopefully you chewed out the dealership
Chris
Old Nov 6, 2006 | 10:19 PM
VetteDrmr's Avatar
VetteDrmr
Old Nov 7, 2006 | 05:13 PM
bobvet7's Avatar
bobvet7
Default Harsh ride? Get the Edelbrocks.
Harsh ride on my 04 coupe was helped by insulation and losing the runflats, but only the Edelbrocks solved the problem for good. Handles as well or better.
