best shocks for 2004 base coupe
I've not heard of a "soft" ride other than stock shocks..Are they original or aftermarket?
Just replaced my RF's with Goodyear F1 GS-D3's. What a major improvment in the overall ride. Quiet, smooth, and sticks like crazy. Stero sounds better than ever, and I love the slight gear whine going through the gears that I never heard before.
you dont want to take away the "already deprived" handling just to get a softer comfy ride. going non-run flat tires is a better option.
Check this first. Do not exceed 30psi.
Clayton from Las Vegas
It's a GM shock..you can get 'em here hardly used for 150.00 or so..Or you can get 'em new from a Supporting Vender here like Fitchner for 300 give or take... I went used and they are firm but not harsh. You wouldn't be dissapointed with used Z06 shocks. I figure if I didn't like them I could resell em anyways. I like 'em though.
If you don't have the F55 option, then the next thing to check is the ride height. Many people have lowered the car using the stock height adjusters, and it's possible to have the car lowered enough to cause the shocks to bottom out when hitting a bump, again leading to a harsh ride.
Finally, as mentioned above, the run flat tires are pretty stiff springs in their own regard, so make sure you run right around 28-30 psi cold in the tires.
But, you'll never get the ride as soft as a normal passenger car. Nor should you expect it to. Low profile tires, sports car suspension (even the base version) equal a "sporty" ride feel. It's part of the package.
HTH, and have a good one,
Mike
the first thing I thought of when he mentioned "the ride is very harsh."
