Help with sound??
Nov 3, 2006 | 09:23 PM
Help with sound??
I have the b&b with stock cats. How do I get rid of that marine engine sound? Dont know how to describe it but it sounds like the pipes are in water??
Nov 3, 2006 | 10:50 PM
Cruise-In VIII Veteran
Quote:
I don't know from experience, but others on here have said that if you add an X- pipe that it will eliminate it.
Nov 4, 2006 | 03:38 AM
what is the best one and best price?
Nov 4, 2006 | 08:13 AM
**Get an X-Pipe**
The Corsa cost $300, Bassani=$400, Borla=$400, Magnaflow=$300*I personally like the (Bassani) but thats just my opinion..My second choice would be probably the magnaflow. These Xpipes are rated at about 4-6 HP each on average. I used to have the Bassani before the 3" Kooks & they make a great product which I thought sounded great and elimated 100% of the popping. Best of luck~CHRiS~
*A good X pipe should help with the sound you described..Hope this helps
Nov 4, 2006 | 01:10 PM
I really like my Magnaflow true-x!
Nov 4, 2006 | 07:18 PM
From: Manchester - Political correctness is tyranny with manners.
An X pipe will HELP, but will not eliminate burbling. I put a Corsa X pipe in frint of my Corsa Indies, but got limited results.
Nov 4, 2006 | 09:46 PM
i have a bassani and i like mine.. pm'd u with a place to get it for like 200ish..
Nov 4, 2006 | 11:58 PM
that is cool, thanks for the help
Nov 5, 2006 | 03:57 AM
The cheapest you can find.
Nov 6, 2006 | 01:42 AM
You need a different set of mufflers. Magnaflow's exhaust sounds like a deep muscle car rumble, not an outboard motorboat sound.
Nov 6, 2006 | 07:55 AM
I thought that was part of b&b's trade mark sound?
