How to Clean MAF (one with the screen)???
. Cleaned that and it has been drying since last night. Hope this helpsNow on to the MAF. I took it off to inspect it, you can only see ONE side of the wires, because I have a screen on one side.
It doesn't loo overly dirty? But the outside of the screen has some type of dried stains on it? oil, or maybe just a wear in the screen material that changed to a different color???
Lets get to my question:
1.. OK MAF is OFF, want to clean it just in case. I searched and it said electronics cleaner from Radio Shack??? Is this right?
2. I would only be able to spray/clean 1 side (the side facin g the tb) since the other side of the MAF where the AIR is actually flowing into has a screen on it.
Do I spray the SCREEN as well??????????? or just the one side?
Also any tips on exactly how much to spray. I know not to touch it!!
Gary
So you actually stuck that attachment in the screen openings (the tiny holes) and sprayed the cleaner from the screen side as well?
What do you spray exactly? All the exposed wires/metal Pins inside ther MAF
THANKS............
If you look inside the MAF from the OPEN side it almost looks Like (3) bars on one side (Left) , and (2) Bars on the other (Right)>
This is what you spray?
Also, any specific name brand cleaners? AND where did you buy them at?
http://www.crcindustries.com/auto/co...x?PN=05110&S=Y
HTH!
Thansk Again Guys!!
Thanks for the Link RTSVette!!!Wish I could just go buy that locally. I was going to go to Radio Shack and get electronics cleaner.
hmmmmmmmmmmmmmmm
You should be able to get it at your local parts store i got some at autozone here where i live.
Oh i tried that radio shack electronics cleaner it was a waste of money on the maf as far as i was concerend.
Go to your local autoparts store and get a can of MAF cleaner.
I sprayed it on BOTH sides, including right through the MAF Screen. It didn't look dirty, but who knows. I cleaned it and will reattach it when my air filter drys off and I lightly oil it.
Thanks so much!!!!!!!!
I cleaned my airfilter as well which was FILTHY
so hopefully the combined output of cleaning both will be realized.I was down 30-35 rwhp on the dyno recently and was trying to figure out WHY. My car should be around 395-400 rwhp and it was 360.
I had a broken valve spring that was replaced (actually did the whole set was replaced) so I thought there might have been valve float/dammage................I just hope it was something simple like a dirty clogged air filter and a slightly dirty MAF.
Lucky I had DUAL Springs as the inner spring held up
The hardest part of cleaning the MAF was getting the electrical connector to come unplugged on the the MAF.........
It's probably okay for the older 3-wire style with the metal ends.
Too late now.....
So you are saying craze as in weaken then crack??? I guess I should check for this...???
DH
