I was planning on adding Z51 bars to my standard suspension coupe. Looks straightforward, anyone know of any tips I should be aware of? Is it possible to make the change using only a floor jack, jacks stands and maybe rhino ramps? Don't have access to a lift. Thanks.
Re: Can Stabilizer bars be changed without a lift? (JohnS)
JohnS,
The thing to watch out for is having enough room to use the torque wrench properly. I changed sway bars using a lift and on ramps and I'll tell you a lift is much easier. However, it’s not impossible to do with ramps if you take your time. One other thing, I used a crow’s foot socket in order to torque the links while you hold the Torx head screw in place. A little awkward, but it works. Good luck. – C.
Re: Can Stabilizer bars be changed without a lift? (IAdvise)
Here is a note that may help.
On the end links, remove them first and mount them to the new sway bar before mounting on the car, then mount the bar and do the lower control arm/end link connection. It is extremely hard to get a wrench on the top of the end links with everything mounted.
It is easier to mount the new swap bars if the suspension is unloaded, ie jack the front up and support it with jack stands.
I would also recommend using the steel end links on the front since the plastic stock ones can tear.
Re: Can Stabilizer bars be changed without a lift? (RedLandRocket)
Not to hard pretty straight forward, I printed out Mallett's installation instruction off their website just for reference. Something Paul from VB&P told me is that their should be no tension on the end links if you are using the metal ones, if not just observe the locations prior to removal and replace the same. Mallett's main point was just to make sure that it is not hitting anything.
IAdvise,
A crow's foot socket looks like the end of an open end wrench that has been cut off, and a 3/8" drive square hole put in to connect to a ratchet. You can find them at most automotive stores or Sears, if you want to spend a bit more. - C.
Re: Can Stabilizer bars be changed without a lift? (JohnGlenn)
Mr C,
Thanks, I was browsing the net and the only thing I found was a torque wrench for about $400 that has an adaptor! Finding it at Sears makes it MUCH easier
Thanks again
Thanks for all your replys (I've been out of town for a few days). I think I picked up enough tips to feel comfortable trying this this weekend. The tip about putting the endlinks on the bars first before installing the bars may very well have save me a lot of time and aggravation.
