02 Sensor Voltage
Old Nov 8, 2006 | 07:39 PM
427CPE's Avatar
427CPE
Default 02 Sensor Voltage
An increase in o2 sensor voltage is RICHER or LEANER?
Old Nov 8, 2006 | 07:45 PM
gpracer1's Avatar
gpracer1
Richer. A "rough" value of .89 at WOT is good.
Old Nov 8, 2006 | 08:26 PM
427CPE's Avatar
427CPE
Thanks for clarification. Now, I just changed out my cam. The one I (MSI, thanks) put in is a 216/222 585 on a 116 is very mild and the car has great manners. I can feel the power improvement, but now want to tune.
I use HP Tuners. before I changed the cam, I datalogged it at WOT.
Like you state, I found the o2 sensors running around .905v-.910v w/stock cam. Data was logged several times for verification.
After the cam install, I'm seeing data:
4200-5200: ~0.938v
5200-5500: ~0.929v
5500-6500: ~0.920v.
Ah, work to do... Any ideas for the best peak performance, please post...
Old Nov 9, 2006 | 03:51 AM
427CPE's Avatar
427CPE
Just got back from tweaking the PE table. The engine really screams at around 890-900mv. I wonder what A/F that equates to?
Old Nov 9, 2006 | 05:41 AM
vettenuts's Avatar
vettenuts
Are you using a wide band? I wouldn't use the narrow band O2 for tuning.
Old Nov 9, 2006 | 09:39 AM
muncie21's Avatar
muncie21
Agreed!! Look at the output signal of a factory O2 below and tell me if you want to tune your motor with it.....
Old Nov 9, 2006 | 10:54 AM
427CPE's Avatar
427CPE
Its all relative. The car in stock form stayed within 20mv of each pass at WOT. I was able to do the same w/the new cam. Actually works well.
Old Nov 9, 2006 | 02:31 PM
MGorman's Avatar
MGorman
Just because it’s consistent, doesn’t mean it’s accurate.
Narrowband O2 sensors are only accurate at 0.5v (14.7:1). Higher and lower voltage readings may be consistent but they are not accurate in terms of A/F ratio.
Old Nov 9, 2006 | 09:59 PM
427CPE's Avatar
427CPE
It doesn't matter what the A/F is as I am not using them for A/F. Let me explain. In both my 02 and 03 Z, I datalogged the stock engines many times. In both cases, the engines/02 sensors continually produce 02 voltages that in my opinion were consistent to around 20 millivolts. This voltage is relative and the A/F is irrelevant. The voltage produced is consistent. This voltage gives me a 1:1 correlation w/the [stock A/F] that GM thought made good power and was safe.
I don't really need to know what this A/F is since I trust the car was already making great power stock.
What I already know is that my car runs 12.4:1 at WOT completetly stock. A slight leaning of the engine produces more power which is exactly the relative change I see in voltage and power. IE, it works well.
I had TWO widebands mounted in my rear sensor slots in my 03 Z.
It didn't mean squat. After tweaking power on the dyno, I found the best (RELATIVE) A/F for that meter was 11.7:1 for my car's combo /tune. You can't put every tune in to a neat little wideband box. It doesn't fit. You gotta learn to use all the tools avail to you. This one works great.
To 02 Sensor Voltage
