True or False?
Old Nov 9, 2006 | 03:32 PM
jan-db's Avatar
jan-db
Default True or False?
I read somewhere on this great forum that one of the "Corvette Secrets" is to click the emergency brake once to turn off the running lights. My '01 doesnt do it. Have I been lied to?
Old Nov 9, 2006 | 03:48 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
I have heard that also, but never tried it. Also, while moving in reverse if you click the e brake handle that's how you adjust it.
Robert
Old Nov 9, 2006 | 04:01 PM
TSDuke's Avatar
TSDuke
I just pulled the fuse for my daytime running lights. The only drawback being that the rear approach lights don't work when you do this.
Old Nov 9, 2006 | 04:11 PM
middlebrookgt's Avatar
middlebrookgt
it just depends on how easily your limit switch on your emergency brake handle is triggered. It may take two clicks to hit the switch and turn the lights off. Purely a mechanical/physical thing. While parked with the lights on, pull up on the handle one click at a time, giving the relays time to turn off and close the lights between clicks. Then you'll know how many clicks it takes to keep your lights off. Or just turn off your Twilight sentinel option on the DIC.
Old Nov 9, 2006 | 04:59 PM
SpeedyZ's Avatar
SpeedyZ
I tried to get this to work on a 04 Z06 and it did not work.
Old Nov 9, 2006 | 05:01 PM
C5XTASY's Avatar
C5XTASY
That won't do anything except keep the headlights and parking lights from turning on and off automatically. I do not use twilight sentinal, anymore, in order to keep from cycling the headlights whenever I garage the car. That does not affect my running lights. They stay on all the time unless the e-brake is engaged, as discussed above.
BTW: I believe the key has to be turned to the "run" position to have the running lights turn off in this manner, but really don't remember. The car is in hibernation or I'd run out and check. There is a particular sequence. Check with someone with a Hypertech Programmer. The way you do it is discussed in the instruction manual. They do engage the parking brake to turn off the running lights in order to minimize battery drawdown while programming. At least it was in the manual for mine when I was using one.
Ed
Old Nov 9, 2006 | 05:27 PM
The Wrench's Avatar
The Wrench
As stated above, the easiest way is to pop the "approach" fuse.
As he said, the only negative is when you hit the remote unlock at night the backup lights to not light-up. However, the taillights, parking lights, turn signal lights, interior lights still turn on. I haven't had any problem finding my car with only these 12 lights turned on. Ha.
DG
Old Nov 9, 2006 | 05:52 PM
Rex99Coupe's Avatar
Rex99Coupe
On mine the e-brake has to be one click before you put the key in, to disable the DRL's.
Old Nov 10, 2006 | 02:11 AM
JH's Avatar
JH
I guess I don't understand why one would want to shut off the DRLs. They increase visibility, and for lots of the popular auto colors -- gray,charcoal, silver, black -- they could save your life from some inattentive driver who fails to see you and pulls out in front of you.
Each to their own, but I will leave them operational!
Old Nov 10, 2006 | 04:47 AM
molten vett's Avatar
molten vett
some people disable them because it tends to wear the headlight gears out quicker which are pretty vulnerable already.
Old Nov 10, 2006 | 06:20 AM
LAYNLOW's Avatar
LAYNLOW
I'm just wondering why you wouldn't want them on?
Old Nov 10, 2006 | 06:33 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
It doesn't work on my vette but it does work on my TA
Old Nov 10, 2006 | 06:39 AM
HeadHunter1's Avatar
HeadHunter1
The DRLs don't open the headlights. Why would it wear out the gears?
Old Nov 10, 2006 | 09:44 AM
BRKLYN's Avatar
BRKLYN
DRL's were made with safety in mind.I guess if we did'nt have it,we would complain for havind to turn on manually.I remember when we alway' drove with the parking brake light on,with our sixties muscle machine's.Don't stress and be safe. Nelson
Old Nov 10, 2006 | 10:07 AM
chaase's Avatar
chaase
St. Jude Donor '12
DRL's are not the headlights!
Old Nov 10, 2006 | 10:13 AM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
I tried it and it worked but it did have to be BEFORE I insert the key. After the key was in, and the lights were on, it didn't turn them off.
Old Nov 10, 2006 | 10:57 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
If you have black covers on... or like me have black tinted signal lenses you don't want the DRLs shining through ruining the look. Thus, pull the #2 fuse and their gone
Here's a rolling pic (my avatar)
To True or False?
Old Nov 10, 2006 | 11:24 AM
IrishJoker's Avatar
IrishJoker
Uh.....the DRL's have nothing to do with cycling the headlights ON or OFF.
Old Nov 10, 2006 | 11:26 AM
IrishJoker's Avatar
IrishJoker
In most states running with "BLACK-OUTS" is illegal anyways. Especially over your turn signals.
Old Nov 10, 2006 | 11:55 AM
Tigershark3's Avatar
Tigershark3
DRL's don't have anything to do with the headlights cycling up and down.
