True or False?
Old Nov 10, 2006 | 12:15 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Originally Posted by Tigershark3
DRL's don't have anything to do with the headlights cycling up and down.
Yes that is true, but the kind of person who disables the DRLs would think that.
Old Nov 10, 2006 | 12:28 PM
TroutFisher's Avatar
TroutFisher
DRL= Daytime Running Lights (the orange ones)
Old Nov 10, 2006 | 01:32 PM
TSDuke's Avatar
TSDuke
Old Nov 10, 2006 | 01:44 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Originally Posted by IrishJoker
In most states running with "BLACK-OUTS" is illegal anyways. Especially over your turn signals.
Who cares... they're tinted so when the headlights are on they shine orange and the turn signals shine through just fine.
Old Nov 10, 2006 | 02:28 PM
OhioDave's Avatar
OhioDave
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'17-'18-'19-'20-21
Daytime Running Lamps on with Blackouts and Fog Lamps on.
DRL has nothing to do with the headlights. Twilight Cenntinel will automaticly raise the headlights due to darkness.
Old Nov 10, 2006 | 06:14 PM
davee01's Avatar
davee01
This works on my 1999 Chevy Astro van.
And sometimes during a messy divorce from the ex wife, I had to park with no lights on to monitor and not be noticed. It was not for driving without them since there really isn't any way to make that box on wheels look too cool.
Old Nov 10, 2006 | 07:22 PM
VicCaerter's Avatar
VicCaerter
Originally Posted by Todd157k
I tried it and it worked but it did have to be BEFORE I insert the key. After the key was in, and the lights were on, it didn't turn them off.
you are correct sir 100% dead on.
Old Nov 10, 2006 | 07:39 PM
WilliamCall's Avatar
WilliamCall
Originally Posted by Cobra4B
If you have black covers on... or like me have black tinted signal lenses you don't want the DRLs shining through ruining the look. Thus, pull the #2 fuse and their gone
Here's a rolling pic (my avatar)
I like your picture. My compliments to your photographer.
Old Nov 12, 2006 | 06:20 PM
Vetteoholic's Avatar
Vetteoholic
Originally Posted by TSDuke
I just pulled the fuse for my daytime running lights. The only drawback being that the rear approach lights don't work when you do this.
Old Nov 12, 2006 | 08:25 PM
Patches's Avatar
Patches
Mine shine through the blackouts just fine.
Old Nov 12, 2006 | 08:41 PM
Gannet's Avatar
Gannet
St. Jude Donor '06
Post #3 in this thread describes a simple method for disabling the DRLs that is fully reversible, zero cost, throws no codes, and keeps your approach lights. It only takes a few minutes.
Old Nov 13, 2006 | 09:23 AM
Z28TOZO6's Avatar
Z28TOZO6
I have an o3 z. Mine must be turned off as my lights do not come on unless I turn them on. Was the Z different from regular c5's?
Old Nov 13, 2006 | 09:28 AM
  #33
Cobra4B's Avatar
Cobra4B
Thanks!
Old Nov 13, 2006 | 01:54 PM
  #34
white90conv's Avatar
white90conv
On my 2000, if you release the hand brake completely after the key is on, the drl's come on and stay on. If you release the handbrake before inserting the key and then pull the hand brake one notch and leave it there, they do not turn on when the key is inserted.
Old Nov 13, 2006 | 02:51 PM
  #35
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Originally Posted by molten vett
some people disable them because it tends to wear the headlight gears out quicker which are pretty vulnerable already.
Isn't it the two front amber lights that are the DRL's (US cars) not the headlights?
The Monk!
Old Nov 14, 2006 | 01:43 AM
  #36
white90conv
The drl's are the turn signal bulbs.
Old Nov 14, 2006 | 02:12 AM
  #37
Blue Blood's Avatar
Blue Blood
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
The DRL's make advance notice of the Corvette wave much easier to prepare for.
Old Nov 14, 2006 | 03:32 AM
  #38
DeeGee's Avatar
DeeGee
True but its then v embarrasing when you wave to the other GM cars that all have DRLs:o
I guess the original poster got the answer. My view is that DRLs are a waste of space. If the other driver needs DRLs to alert him/her of the presence of another vehicle be afraid; be very afraid If visibility is reduced you should be using dipped headlights
JMHO
BTW Amber DRLs are illegal in Europe. The only amber lights are turn signals and that way there's no confusion. I did the relay/jumper mod to disable my DRLs but the A2 fuse is by far the easiest mod.
Old Nov 14, 2006 | 05:52 PM
  #39
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
