Adjusted my Shift Linkage... WOW what a difference!
Old Nov 13, 2006 | 10:41 AM
cruisemon's Avatar
cruisemon
Originally Posted by chuckster
I also plan to do the AntiVenom mod..I don't want to take ALL the notchiness out of my shifts.. just a little...
I went to the other thread from '05 and probably missed them, but is there a chance someone has a photo or a diagram that shows the bolt that is to be removed and the washer installed?
Found a photo on this link, 15th post down
http://forums.corvetteforum.com/show...ight=antivenom
FWIW - tried to contact the guy that had the Antivenom machined part and the phone is NG and the web page is gone. I wonder if so many people finding about the 75 cent washer sort of killed off the $60 machined part?
Charlie
Old Nov 13, 2006 | 03:36 PM
CodeName Z06's Avatar
CodeName Z06
I have done the antivenom and adjusted the linkage and it shifts much better than before the only problem i still have is going into reverse, it is still a bit notchy unless i go from 1st to reverse then its smooth.
Anyone else have this problem?
I highly recommend for everyone to give these to things a try, it will really improve the feel of the shifts.
PS Who would want to order a $60 bolt when you can go a couple of blocks to an autoparts store and get a $1.25 pair of washers.
Old Nov 13, 2006 | 03:43 PM
cruisemon's Avatar
cruisemon
What can be done to reduce the amount of force needed to go through the neutral gate when going into reverse? It is REALLY stiff on my car to the point that I have to sort of brace against the seat to push hard enough on the shifter to get over to the reverse gate. Will the washer on the bolt affect this?
Charlie
Old Nov 13, 2006 | 09:10 PM
cruisemon's Avatar
cruisemon
Couple of posts in here mentioned lube leaks. Would a nylon spacer instead of the copper washer be better for sealing?
Charlie
Old Nov 13, 2006 | 09:37 PM
jbone's Avatar
jbone
When I put my b&m ripper shifter in I took that rusted looking pin out(i think you said allignment pin) out. Is that bad? What does it do?
Old Nov 13, 2006 | 10:43 PM
CodeName Z06
I don't think you need it since it is in the out position normaly and you put it in only to readjust the shifter.. What it does is it locks the linake shaft in neutral.
Old Nov 13, 2006 | 11:58 PM
jbauch357's Avatar
jbauch357
Charlie
yes, this will drastically help with getting the car into reverse and going from one gear to another. another thing to pay attention to is you may be past the gate, but not all the way into gear. to get that last 1/8" into gear let the clutch out very slowly while still lightly pushing on the shifter and you will feel it pop into place.
Charlie
Sealing really shouldn't be an issue since the bolt sits so high on the transmission, just make sure you have clean surfaces for a good seal.
Old Nov 13, 2006 | 11:59 PM
jbauch357's Avatar
jbauch357
just make sure to hold on to the pin so you can lock the shifter in neutral for future linkage alignments, alternatively people have used the correct diameter drill bit.
Old Nov 14, 2006 | 09:47 PM
chuckster's Avatar
chuckster
Originally Posted by tstar
I am too... let me know if you end up using one or two washers, I've heard of people doing it either way.
Thanx!!
Tim
99 Coupe
Ended up using one washer... It have me just the right adjustment.. Got it from Ace Hardware.. Home Depot and Advanced Auto had nothing.
Also I used some teflon tape on the threads to ensure I got a good seal.. because it looked as though there was thread locker on it from the factory..
Old Nov 14, 2006 | 10:02 PM
LoneStarFRC's Avatar
LoneStarFRC
No worries on the pin. A 1/8" drill bit shank fits perfectly. Since I removed the pin and didn't want to leave the hole exposed, I first squirted a drop or two of synthetic motor oil into the hole and then just "wiped" a small dab of black silicone over the hole to seal it. Easy to remove later if necessary. The front section of the shifter shaft is supported at this point and is constantly rotating and/or moving back and forth as you shift. Lubing here is good.
Robert
Old Nov 14, 2006 | 10:22 PM
cruisemon's Avatar
cruisemon
Just to be on the safe side, remind me of the washer dimensions. I think it was 3/4" ID but what thickness? 0.080" or thereabouts maybe?
Charlie
p.s. - I like the dog.
Old Nov 14, 2006 | 10:57 PM
chuckster's Avatar
chuckster
Charlie
I am pretty sure it was like 1/16" and yes about 3/4"
Old Nov 18, 2006 | 04:56 PM
  #33
bomax's Avatar
bomax
Where did you guys get your washers at? I just hit Ace Hardware, NAPA, Autozone, O'reillys, and Lowes and nobody had them in the right size.
Old Nov 18, 2006 | 05:14 PM
  #34
chuckster's Avatar
chuckster
The washer I got at ACE was a big washer.. stuck out at least 1/4 around the bolt... They were in the Metric Washers.. I think.. Bring the bolt with you.. then you can try them all
Old Nov 18, 2006 | 09:30 PM
  #35
VETTING's Avatar
VETTING
I usually put mine into first gear and then into reverse. If I try to go into reverse when it's cold right away it's a little stiff. After I drive a little it loosens up. Is this normal? The car sit's for a week at least between usage's.
