3rd brake light
Old Nov 11, 2006 | 08:50 AM
theinvid's Avatar
theinvid
Default 3rd brake light
forgive my newbiness...but I have a light bulb out (i presume) on my "3rd" brake light. uhhh how do you get to it to change the bulb??
Old Nov 11, 2006 | 09:00 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
LED's, remove the inner taillight on either side, 2 7mm screws and a plug, I think you will need the whole assembly
if anyone has experience replacing individual LED's step in
Old Nov 11, 2006 | 12:57 PM
theinvid's Avatar
theinvid
any idea what the whole assembly sells for?
sounds like a design flaw to me. shoulda been easy access and change a bulb.
damn GM!
Old Nov 11, 2006 | 01:19 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
It's not a "bulb," and the easiest way to access it is by removing the license plate / backup light assembly and reaching straight up.
Images courtesy "Patches"
Old Nov 11, 2006 | 05:34 PM
DngrZne's Avatar
DngrZne
If it's the whole 3rd brake light that's out, you might just have to reconnect the wire to it again. When I had my 97, the light was out and the fix was as simple as plugging the wire in that fell out
Old Nov 11, 2006 | 10:21 PM
USA C5's Avatar
USA C5
Default Corvette Parts/3rd Brake Light
Try this supporting dealer on monday:
www.FichtnerChevrolet.com
Great Prices, Service, and People!
Old Nov 11, 2006 | 10:33 PM
Mike Mercury's Avatar
Mike Mercury
Originally Posted by connecticut
LED's, ...
I cut mine apart. And you could change one of the bad LED's - except... EXCEPT you'll never find a source for the exact same ones that are already in there.
Sure you can substitute in a similar LED. But now... instead of one (of many) "bulbs" being out... you'll have one that is oddly shaped - or a slightly different brightness. And it still might look as goofy as it did with just the one LED not being lit.
The only solution I can think of to try & continue using your existing CHMSL is to disable the opposing sides good LED. So that you'll now have two "bulbs" out - but they'll be evenly spaced across the entire CHMSL.
But to do this, you'd still have to cut the thing apart, and then glue it back together again.
Old Nov 12, 2006 | 08:09 AM
theinvid's Avatar
theinvid
USA_C5, i sifted through every page of their parts section online and didn't find the 3rd brake light.
-- I hope it's only a disconnected wire...that would be nice.
I'll have to pull out the reverse light/license plate deal and hope not to F that up so I can see if it's just the plug or what. UMM...so HOW DO I TAKE OFF THE REVERSE LIGHT/LICENSE PLATE DEAL?
Thanks for the help guys.
Old Nov 12, 2006 | 01:58 PM
theinvid's Avatar
theinvid
THANK YOU GUYS!!!!!!!!!!!
it was just unplugged.
found a nice link that illistrated how to take the license plate deal off.
just for future reference of ppl in need here it is
pictures and all
http://www.autoelectronicupgrades.co...ll/install.htm
(this site is showing you how to install some blinker deal but it shows how to remove the license plate...which turns out...is super rediculously easy.)
Old Nov 12, 2006 | 03:23 PM
Patches's Avatar
Patches
Even easier if you take one of the tail lights out - two screws and 30 seconds, you're in.
Old Jun 26, 2011 | 12:05 PM
Smith Valley NV's Avatar
Smith Valley NV
4th Gear
Default Third break light - C5
Thanks for the help, all. My 03 C5's 3rd break light was not working. Took advice of removing inside break light, reached in and giggled the connection to the '3rd' and it fixed it. Great forum - I am in.
To 3rd brake light
