Horn and Outside air Temp
Old Nov 12, 2006 | 06:04 PM
Madddogg's Avatar
Madddogg
Default Horn and Outside air Temp
Does anyone know why the horn and outside air temp would go at the same time on my C5(air temp reads 69)? I pulled the horn out today thinking it was something obvious but it's not. I don't know how to check the horn electrically, and don't even know where the outside air temp sensor is. Any advice??
Thanks.
Old Nov 12, 2006 | 06:09 PM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
Outside air temp sensor is on the lower right side, on the radiator shroud. If it is open (ripped off, been there done that ) it will read 69. It will thow a code on your Drivers Interface Councel, in the HVAC, and a C (current) means it still can not read from it. Horn??? Good luck!
Dave
