Replace entire Differential or just gears?
Old Nov 13, 2006 | 12:53 PM
C6NRED's Avatar
C6NRED
Default Replace entire Differential or just gears?
I have a 98 A4 with the 3.15's. As the diff is leaking slightly (common, I know...) I thought as long as they were going to R&R that, this would be a good time to go to 3.73's.
My question is this ---- there is a really good Corvette and Mustang racing shop available to me. Can the gears be changed by a competent mechanic or is the alignment of the ring and pinion so critical that it would be best to purchase an entire diff and have them install that?
Old Nov 13, 2006 | 01:17 PM
Blue02ws6's Avatar
Blue02ws6
My questions is this ---- there is a really good Corvette and Mustang racing shop available to me. Can the gears be changed by a competent mechanic or is the alignment of the ring and pinion so critical that it would be best to purchase an entire diff and have them install that?
I got mine change and they are perfect, no whine. It all depends on the person changing them.
Old Nov 13, 2006 | 01:32 PM
tiojames's Avatar
tiojames
Default gears
Since yours is a 98 I would recommend buying a new diff- a little over a $1000 and selling your 3:15s to some one with an a4 who has 2:73s. That way you will have new gears, posi, bearings, plus not have to worry about the setting up of the new gears in your old diff. Andy at A&A did mine and I sold the 3:15 diff here on the forum. Also the labor is less to change a diff compared to pulling one apart and installing the new gears. Godd luck with what ever you choose to do.
To Replace entire Differential or just gears?
