Broken weld
Old Nov 14, 2006 | 07:48 AM
Dirty "OLE" Man's Avatar
Dirty "OLE" Man
Default Broken weld
This past Sunday I was on I-10 in Louisiana. It is one rough SOB. Well, my car has stock mufflers. The weld on the flange on the muffler pipe broke clean off. The muffler pipe dropped down from the X-pipe and we had to listen to a straight exhaust from underneath the car for the next 40 miles going home. I removed the driver side muffler last night (the broken one). While under the car I noticed that the passenger side flange to muffler pipe had already been rewelded. All of the weld is still on the pipe and not on the flange. It looks like a metal fatigue issue. Has anyone else had this problem? Or is it an isolated issue. I won't be riding on that stretch of I-10 again between Lake Charles and Vinton in the Vert.
Old Nov 14, 2006 | 08:11 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
It is quite common, my 2000 never broke, but when I replaced them you could see they were ready to seperate. Just have them re-welded like the other side.
Old Nov 14, 2006 | 08:47 AM
3rd Childhood's Avatar
3rd Childhood
I had one break too. The muffler shop I took it to said they see it all the time.
Old Nov 14, 2006 | 08:58 AM
Dirty "OLE" Man
Thanks, I am gonna reweld it this afternoon. I want to change out the mufflers. Give it a little more rumble. Don't want it too loud at hiway speeds. Just a good mellow tone. Any suggestions?
Old Nov 14, 2006 | 09:00 AM
j99vette's Avatar
j99vette
Happened to me with Corsa's. Only cost me $20 bucks to get fixed. The welder told me that the cause is the way the muffler and tips are set up there needs to be some other type of support for the weight. I didn't mind the drive with the straight pipe. Thought it sounded pretty good.
Old Nov 14, 2006 | 10:21 AM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
This is very common:
Mine were re-welded before i owned it. Too bad they welded over each of the bolts connecting the mufflers to the Hpipe. I finially realized I wasnt going to budge them when I upgraded to Corsas...I had to take it to the local shop and have them cut the bolts free from the welds.
Also, be careful about driving without the mufflers connected to the Hpipe...I have read on this forum where some guys drove without their mufflers and then realized the heat from the exhaust contributed to a broken rear leaf spring...
Here is a link from the past...Im post #7:
http://forums.corvetteforum.com/show...highlight=weld
Old Nov 14, 2006 | 05:26 PM
middlebrookgt's Avatar
middlebrookgt
I learned something else today!
To Broken weld
