LS6 valve spring failure: any '04's or '01's?
Old 11-14-2006, 06:46 PM
ZeeOSix
ZeeOSix's Avatar
Originally Posted by Cobra4B
Are you serious? They fail all the time... but people don't cry about quality b/c everyone blames the higer lift cam.
I'm talking with a STOCK cam ... not a high lift aftermarket cam. How many aftermarket springs that are intended for stock LS1 or LS6 engines have failed?
Old 11-14-2006, 07:11 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Hmmm... that's a rare scenario... most running a stock cam keep the stock springs.
Old 11-14-2006, 08:00 PM
ZeeOSix
ZeeOSix's Avatar
Not really ... many of the guys who have had stock spring failures usually put aftermarket springs in with the stock cam … maybe adding different push rods too. I'm wondering if any of those guys have subsequently had those aftermarket springs fail?
Old 11-14-2006, 10:00 PM
Cobra4B
Cobra4B's Avatar
All I'm saying is that the yellows aren't as bad as people make them out to be... in fact, they're great. Failures are accross all years, even '01s and even LS1's.
Old 11-15-2006, 03:11 AM
ZeeOSix
ZeeOSix's Avatar
I hear ya, but it just seems like there are more failures than one would expect. Who knows what the root cause is ... could be a number of things: bad batches of springs, owners abusing the car, missed shifts into a lower gear causing over-reving, over reving with a cold engine, owners putting in bigger cams, etc.
But if it's really bad metallurgy/quality then it might be wise to change to an aftermarket spring that has a better quality and reliability reputation. That's what I think most people are trying to determine.
Old 11-15-2006, 08:40 AM
sothpaw2
sothpaw2's Avatar
Originally Posted by torchredfrc
I had a set of aftermarket Manley springs fail recently. Switched to 918's and have been happy since. Valve did not touch piston as far as I can tell. I do have an aftermarked MTI (Houston) C2 cam .576/.576 224/224 112 LSA. Gotta pay to play; Good luck finding your replacement springs. For your purposes, I think I would stick to the yellow LS2 springs.
Are the LS2 springs currently going into new C6's the exact same spring as is in my 2002 LS6? Same as in the 2004 LS6? Just different batches?
Old 11-15-2006, 09:55 AM
Cobra4B
Cobra4B's Avatar
I'm pretty sure that the LS2 is using the yellows as well but I'm not 100%. The LS2 is the same 243 casting head but w/ the '01 spec cam.
Old 11-15-2006, 12:14 PM
vettenuts
vettenuts's Avatar
I have heard the same, and with a ramp up in production one would assume that the failure issue has hopefully been resolved and possibly the reasons were addressed through metalurgy or possibly a new vendor. Assuming that the LS2 is also running the same springs, you could check the C6 section for problems as well as the GTO forums. I haven't seen many lately though.
Old 11-16-2006, 12:21 PM
sothpaw2
sothpaw2's Avatar
Originally Posted by vettenuts
I have seen failures reported, and from memory the 02's seemed to be prominent. Not sure on vendors either, my new set of "yellows" that I plan to rebuild my stock LS1 heads with are Made in Germany.
Any one else heard of an '04 LS6 with bad valve springs? Seems nobody can confirm of a failure on the 2004's so maybe it is just a bad batch in 2002.
Quick Reply: LS6 valve spring failure: any '04's or '01's?
