HVAC Problem
Old Nov 15, 2006 | 05:03 PM
99HRDTP's Avatar
99HRDTP
Default HVAC Problem
I have a '99 FRC w/ dual zone climate control and cannot figure out why I can't get the system to stay charged.
I have had it flushed and charged 3 times over the past 12 months and each time, the A/C starts blowing hot air on the driver's side by 3 weeks.
I've checked for leaks and don't see any signs.
Worst of all, when I hook up a pressure gauge, the system is fully charged, but the compressor won't turn on anymore. When I press the A/C button, it blinks three times and then shuts off.
I do not get any codes.
I have tried disconnecting the battery and replacing fuses.
I can't find any help using the search function.
What gives?
Old Nov 15, 2006 | 06:48 PM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I noticed from your profile you are in SC. If the outside temp is below 40 degrees, the compressor won't come on.
Also, if it shows charged with the compressor not running, it likely could be over filled. The level should be checked with the compressor running. Being overcharged will also cause the compressor not to come on.
PS - You have a nice fleet of vehicles there.
Old Nov 15, 2006 | 09:30 PM
99HRDTP's Avatar
99HRDTP
Thanks. The outside temp was over 90 at the time. I'd like to check the level with the compressor running, but unfortunately, the system will no longer turn on to allow this to happen. Would it be worth bleedin the system again and trying to charge? I'm not sure how to do this if the compressor won't engage.
Mike
Old Nov 16, 2006 | 08:18 AM
CARRJET's Avatar
CARRJET
you will have to jumper the low pressure switch
Old Nov 16, 2006 | 09:00 AM
erick_e's Avatar
erick_e
St. Jude Donor '13-'14-'15-'16
Have someone sit inside the car and turn on and off the AC while you listen and monitor the AC compressor. Do you hear the clicking noise of the compressor clutch . If yes, then check to see if the compressor is turning. If no, then check for voltage at the clutch. It is possible that the clutch assembly is going bad.
Old Nov 16, 2006 | 09:36 PM
99HRDTP's Avatar
99HRDTP
I'm unclear what you're saying.
Old Nov 16, 2006 | 09:38 PM
99HRDTP's Avatar
99HRDTP
The clutch does not appear to engage (no clicking sounds at all). Where would I check for the clutch voltage?
Mike
Old Nov 16, 2006 | 10:49 PM
CARRJET's Avatar
CARRJET
it's the switch on the suction line(low pressure) close to your coolant tank, pull plug off and stick a jumper wire between the two slots in the plug, this will engage you clutch providing if what eric-e is saying you have voltage at the plug on the front of the compressor, hope this helps
Old Nov 17, 2006 | 07:43 PM
99HRDTP's Avatar
99HRDTP
Thanks a bunch. Will check it out.
Mike
Old Nov 27, 2006 | 10:49 AM
99HRDTP's Avatar
99HRDTP
Is it the plug snug up on the frame and closest to the firewall? I see two plugs alongside the passenger bank of cylinders.
Thanks.
Mike
To HVAC Problem
