Rear main oil leak??
Old Nov 25, 2006 | 12:00 PM
maestro300's Avatar
maestro300
Default Rear main oil leak??
I've had an annoying oil leak for about 5 months now. I finally had time to get under it (after cleaning the oil from the bottom of the engine)
The drips are so black that you can rub it between your fingers and not see skin color. However, the oil from the dipstick is still clean...hmm
I did the UV dye test and couldn't detect anything in the drips (possibly because they were so dark) but could clearly see it from the dipstick. I did use the yellow glasses as well.
I've linked a picture to what it looked like after driving around the block. Can anybody tell me what sensor that is? It's definately leaking out of that sensor as well.. appears to be leaking where the bell housing mates with the engine block... out of an opening (far left) that is on the bell housing.
I've eliminated this being from the oil sending unit behind the intake manifold. After pulling the intake; I tried to look down the back of the engine and didn't see any oil.
Is this possibly the rear main? I've heard in the neighborhood of $1200 to get that fixed. It just seems strange that it leaks out of that sensor as well. Any help is appreciated!
http://img131.imageshack.us/img131/5073/leakingcq0.jpg
This is on a 2001 C5 M6
Old Nov 25, 2006 | 12:37 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
That screams rear main to me... mine started seeping at 55,000 miles last summer... glad I had an extended warranty and needed a clutch anyway.
Old Nov 25, 2006 | 05:46 PM
cebars's Avatar
cebars
May or may not be rear main. See post re Service Bulletin on engine block porosity by Bowtie Bandit in thread:
http://forums.corvetteforum.com/show....php?t=1544166
Old Nov 25, 2006 | 08:24 PM
erick_e's Avatar
erick_e
St. Jude Donor '13-'14-'15-'16
That is the oil level sensor
Old Nov 25, 2006 | 08:32 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I would say your quote is double the typical rate, GM has an updated rear main seal
Old Nov 27, 2006 | 11:02 AM
maestro300's Avatar
maestro300
Thanks; I called Chevy they said 9.5 hours at $91/hour plus parts...grrr
I looked at that TSB but was listed Corvettes 2003-2006; would the 2001 still apply in your opinion?
Also; since winter is almost here and the vette wont be driven much... how hard is this for your novice to average home mechanic to do? I'll have all the time in the world but not sure if some special tools are needed. Thanks!
To Rear main oil leak??
