Z06 alignment specs
Old Nov 17, 2006 | 04:48 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
Default Z06 alignment specs
Look at my last alignment #'s and see if I should make any adjustments. The casters nor the cambers on the front equal exactly, but is it too much and should I take it back? My Z was lowered on stock bolts and I'm running 19's on the front and 20's on the rear. The tech kept stating that the difference in the front wheel caster was necessary.
Old Nov 17, 2006 | 05:08 PM
ElectronBlue02's Avatar
ElectronBlue02
Default RE: Alignment Specs
I would take it back to get the front camber, caster and the front/rear toe to be equal.
Your toe should also be equal from side to side, about .03 positive on each front wheel, and 0.0 for each rear.
I would set front camber at about -.6 and front caster at 6.5 for both sides.
From your final specs, my perception is that the guy was having a bad day, or was a little lazy. My car is very sensitive to alignment specs, and yours should track/handle a lot better with better attention to detail.
Old Nov 17, 2006 | 05:29 PM
ErnieN85's Avatar
ErnieN85
as said above it will probably be better if it's equal left to right
the caster is some times ofset to compensate for crowned roads (it pulls down hill) if equal also there should be a slight toe in on the rear to eliminate any possibility of toe out on braking (make it squirley if it toes out under braking)
the specs you gave are probably within the limits however you are paying to have it right not merely close! now that said it's probably why some techs don't like working on vettes (we want it right)
Old Nov 17, 2006 | 05:33 PM
Tact's Avatar
Tact
I forgot to mention that I don't race or track my car, mainly street and a little "spirited" driving. With that being said, would you still have it changed?
Old Nov 17, 2006 | 06:43 PM
Tact's Avatar
Tact
That's why he said he put the caster difference, to compensate for crowned roads.
Old Nov 17, 2006 | 07:41 PM
ErnieN85's Avatar
ErnieN85
At the point you are at if it drives nice I'd leave it alone. To my way of thinking it's not worth aggravating a good service tech if you are not racing (track) who knows when you might need their help?
Old Nov 18, 2006 | 05:54 AM
Tact's Avatar
Tact
If I left the settings as they are, what could I expect in regards to tire wear and handling? The car seems to handle great with no drifting left or right.
Old Nov 18, 2006 | 10:37 AM
ErnieN85's Avatar
ErnieN85
The biggest thing with tire wear (if alignment is correct) is the driver I have heard of 40-50 thousand miles wear with no wheel spin or hard cornering and the opposite 2,000 when you take off hard all the time.
Now for me it looks like about 20-30,000 per set I'm on my third set on this car! the first two getting the alignment right lasted 20,000 this one might make 35,000
To Z06 alignment specs
