P0137 code comes on intermittantly
Old Nov 18, 2006 | 11:18 AM
robl45's Avatar
robl45
Default P0137 code comes on intermittantly
Okay, as the title says I'm getting code p0137 intermittantly. The check engine light will come on, I'll clear it and then it might come on the next day as well. Only seems to come on when I'm driving on the highway. But I can drive all the way to work in the morning and not see it and then usually I'll see it on the drive home from work. I'm guessing its probably not the oxygen sensor itself as it would come on all the time right?
Old Nov 18, 2006 | 03:01 PM
JUSTAKAR's Avatar
JUSTAKAR
Default dic
this is a typical mode of failure from the O2 sensor failure (assuming no exhaust or intake work done) check all fuses for failure as the fuse for heater fail shows this code, hope this helps....all failures of this type show up within 75miles of driving, they also set the service engine soon light both clearable from the dic
CODE LIST partial....
10-PCM - Powertrain Control Module
P0101 Mass Air Flow (MAF) System Performance
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
P0107 Manifold Pressure (MAP) Sensor Circuit Low Voltage
P0108 Manifold Pressure (MAP) Sensor Circuit High Voltage
P0112 Intake Air Temp (IAT) Sensor Circuit Low Voltage
P0113 Intake Air Temp (IAT) Sensor Circuit High Voltage
P0117 Engine Coolant Temp (ECT) Sensor Low Voltage
P0118 Engine Coolant Temp (ECT) Sensor High Voltage
P0118 Engine Coolant Temperature (ECT) Excessive Time to Closed Loop Fuel Control
P0131 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 1
P0132 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 1
P0133 Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 1
P0134 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 1
P0135 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 1 Sensor 1
P0137 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 2
P0138 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 2
P0140 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 2
P0141 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 1 Sensor 2
P0151 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 1
P0152 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 1
P0153 Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 1
P0154 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 1
P0155 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 1
P0157 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 2
P0158 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 2
P0160 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 2
P0161 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 2
Circuit
P0300 Engine Misfire Detected
P0325 Knock Sensor (KS)P0171 Fuel Trim System Lean Bank 1
P0172 Fuel Trim System Rich Bank 1
P0174 Fuel Trim System Lean Bank 2
P0175 Fuel Trim System Rich Bank 2
P0230 Fuel Pump Control System
P0327 Knock Sensor (KS) Circuit Front
P0332 Knock Sensor (KS) Circuit Rear
P0335 CKP Sensor Circuit
P0336 CKP Sensor Circuit Performance
P0341 CMP Circuit Performance
P0342 CMP Sensor Circuit Low Voltage
P0343 CMP Sensor Circuit High Voltage
P0351 Ignition Control #1 Circuit
P0352 Ignition Control #2 Circuit
P0353 Ignition Control #3 Circuit
P0354 Ignition Control #4 Circuit
P0355 Ignition Control #5 Circuit
P0356 Ignition Control #6 Circuit
P0357 Ignition Control #7 Circuit
P0358 Ignition Control #8 Circuit
P0410 AIR System
P0412 AIR Solenoid Relay Control Circuit
P0418 AIR Pump Relay Control Circuit
Old Nov 18, 2006 | 04:33 PM
Mike Mercury's Avatar
Mike Mercury
drivers side, downstream of the cat. Just replace it. Cheap troubleshooting.
Old Nov 18, 2006 | 09:38 PM
robl45's Avatar
robl45
isn't the oxygen sensor like 200 bucks? I'm just worried that maybe its an exhaust leak or something? I had the mufflers welded a year or two ago because they broke at the pipes but it was obvious because of the sound. I live in florida so I don't have to pass emissions, just wish I could stop the codes.
Old Nov 18, 2006 | 10:14 PM
Mike Mercury
since it's a rear sensor, then you could always install sims for both rear sensors.
To P0137 code comes on intermittantly
