Cruise Control Trouble
Old Nov 20, 2006 | 04:00 PM
wheelerb10's Avatar
wheelerb10
Navigator
Default Cruise Control Trouble
I have a 1999 Corvette and the cruise control does not work... anybody know if there is a fuse for it cause i can't seem to find anything?
Old Nov 20, 2006 | 04:34 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Try this first..
While crusing down the road, lift up on your brake pedal, then try the button and see if the system will engage.
The system will not function if it detects the secondary brake switch is closed. On my car, I started noticing an "intermittent" lack of operation, and suspecting the switch, if I lift up on the brake pedal it works every time.
There are a few creative ways to solve the switch issue if that is indeed your problem.
Old Nov 20, 2006 | 04:56 PM
wheelerb10's Avatar
wheelerb10
Navigator
That worked thanks i appriciate it
Old Nov 20, 2006 | 05:07 PM
Dan_the_C5_Man
Great!
Old Dec 27, 2006 | 05:18 PM
wheelerb10's Avatar
wheelerb10
Navigator
Originally Posted by Dan_the_C5_Man
Try this first..
can you tell me these creative ways to fix this. Thanks
Old Dec 27, 2006 | 08:59 PM
Admiral Fairway's Avatar
Admiral Fairway
One way to fix it, is to adjust the stoplight switch which is located at the top of the brake pedal. I was able to just move mine in and out until I had the proper adjustment.
To Cruise Control Trouble
