Rear O2 Simulators
Old Nov 20, 2006 | 06:41 PM
Last C5's Avatar
Last C5
Default Rear O2 Simulators
OK, after waiting over a month for my set of 02 simulators that Thunder Racing said they had and would "ship right out", they sent me my plugs for the pipes and a notation on my bill that I'm getting a credit for the 02 simulators that obviously they don't intend to provide. WHO'S GOT SOME IN STOCK???? Anybody know?? I want to put this thing together and I need some Sims in my state.
Old Nov 20, 2006 | 07:02 PM
sceia's Avatar
sceia
I just got some from corvette garage....they said that the gov't was stopping the production of them....glad I got some when I did!!
Good luck....
Scott.
Old Nov 20, 2006 | 07:27 PM
happa's Avatar
happa
One idea is you can get a tune and get the tuner to delete them out. Good Luck
Old Nov 20, 2006 | 07:28 PM
onewheeldvl83's Avatar
onewheeldvl83
ok listen carefully best best 02 sim get 2 (for each o2 you are simulating) so 4 all together 18mm anti fail spark plug adapters usually found in a help section or something to that effect take 1 drill the center out as big as possable so the 02 fits it connect it to the untouched one (on top only small hole should be shown) put the o2 in and put it in the exhaust alot of times electronic o2 sims give problems i have done this to eveything from corvettes mustangs imports and german it will cost about 12-15 dollars and 1/2 hour of time
Old Nov 20, 2006 | 07:40 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
I don't get it. Is this a homemade sim?
Old Nov 20, 2006 | 08:17 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Great idea, but I tried it for the rear sensors on my C5 and found there wasn't room to reinstall the sensors with the plug extentions in place. Plus, if I dropped the pipes lower to install the sensors, the top end of the sensor hit the floor panel when the pipes were reinstalled.
Old Nov 20, 2006 | 08:22 PM
jdmvette's Avatar
jdmvette
Night Owl for life
i have read that the sims are not known to last long so i went and got the codes tuned out.
To Rear O2 Simulators
