Need ideas for removing a stipped lugnut
Old Nov 22, 2006 | 03:36 PM
gt-hunter's Avatar
gt-hunter
Default Need ideas for removing a stipped lugnut
That's pretty much about it. I have a 12x1.5mm lug that's closed-ended and it's spinning freely on the stud. I got a flat so I need to remove the tire but I can't due to the slipping (stripped) nut.
Any ideas?
Thanks,
Mike
Old Nov 22, 2006 | 04:38 PM
ericdwong's Avatar
ericdwong
Good lord. I think I did that with my old maxima. Drill it out? Careful not to drill thru the rim...
Old Nov 22, 2006 | 04:54 PM
gt-hunter's Avatar
gt-hunter
I don't understand what you mean by drill it out.
It's actually spinning on the stud itself so it's not like I can't put a lug-wrench around it...I can ...it just doesn't spin on the thread.
If I drill a hole into the center of it how would I get it out?
Old Nov 22, 2006 | 05:19 PM
jmiller's Avatar
jmiller
That sounds bad. Is the lug nut tight or loose? At what point did it start spinning? Immediately or half way etc.
I have zero experience with anything like this, but I've replaced the stud a few times. My only guess is that the stud is no longer pulled into the hub (if that makes sense?). If you can tighten the lug, I'd try that.
If the problem is the lug nut, it just needs to get broken better. Like fall off in your hand broken. I'd try calling a discount tire or something and find out how they would break a lug nut (they seem to be able to break my stuff easily). Maybe an air hammer with a small chissel, just hammer the chit out of the end and see if will break the lug apart. Just be careful so you don't gouge the wheel.
Old Nov 22, 2006 | 05:26 PM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
You can try a couple of things.
1. Get some new drill bits and start drilling it out. Meaning use a small bit to drill your first hole, then keep sizing up.
2. If all of the others are off, try pulling the tire from the opposite side to where the lug is. As mentioned earlier, the stud may not be set in proper place. This may either snug the stud in place or might break the stud. (you would have to pull quite hard.)
3. Put the other 4 back on and take it to a tire place/ mechanic and see what they can do.
I actually had a locking lug nut fall apart while putting it on and some was still left on the stud. I had to drill the stud out. That is something I do not want to ever do again! Be careful not to damage your rim!
I hope this helps, Good luck
Old Nov 22, 2006 | 07:05 PM
cruisemon's Avatar
cruisemon
Any ideas?
Thanks,
Mike
If the STUD is turning in the hub that may be a problem. If you are able to drill at an angle next to the lug nut maybe 1/16 away from the stud itself into the hub, drill maybe a 1/8th inch diameter hole and put a drill bit in to lock the stud in place. Wet the stud/nut/theads down with WD40 or some similar compound and SLOWLY turn the lug nut to avoid shock loading the drill bit. If that doesn't work, sell the car and don't tell the buyer the tire is flat.
Charlie
Old Nov 22, 2006 | 07:19 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Any ideas?
Thanks,
Mike
Mike
THE COMMENT about drilling the stud is a good one. Drill a small hole through the lug nut and through the stud. keep increasing the size of the drill bit untill theres not much left of the stud. Once you have most of the inside of the stud drilled out (HOLLOW), then just use the cross wrench or socket that your using to remove the lug nuts and snap off the stud.
Bill C
Old Nov 22, 2006 | 07:20 PM
PA_BLUE_C6's Avatar
PA_BLUE_C6
St. Jude Donor '05-'10-'12, '15
If you have access to a dremel tool, cut the nut at 180 degrees apart with a small cutting bit. Replace the stud so feel free to cut in to it.
Good Luck
Old Nov 22, 2006 | 08:17 PM
CARRJET's Avatar
CARRJET
If you can get a screwdriver in behind the nut, put some outwrd force on it and try backing it off with the force still on the nut
Old Nov 22, 2006 | 08:40 PM
Mudlizard's Avatar
Mudlizard
Good Luck
This is what you want to do right here. I did this before to one of mine and it works great. Lug nut will be off in a couple minutes. Just may need to spread it a bit after its cut thru to get all the way off. Should create no damage at all to wheel. Good luck.
Old Nov 23, 2006 | 12:36 AM
94legaleagle's Avatar
94legaleagle
or try pulling on the rim so that the rim puts pressure on the bad nut - then when pulling on the rim and putting pressure on the nut, see if you can get the nut threads to "catch" and turn the nut off
Old Nov 23, 2006 | 01:07 AM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Old Nov 23, 2006 | 08:54 AM
CTSV OWNER's Avatar
CTSV OWNER
I just ran into this the other day but with a open lug nut. All I did since the threads were bad was air chiseled the stud out of the hub since the threads were not holding tight. Then replaced the studs
I would use a dremil and open the end of the lug nut and try a air chisel to push the stud off the nut.
Old Nov 23, 2006 | 09:50 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
I drilled one out that was freely spinning, I can'r rember what size drill bit I used but it was big enough to completely remove the stud and all I had left was the lug nut, I only spent about 10 minutes with the drill also.
Old Nov 23, 2006 | 12:31 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I had a similar problem and with the help of a fellow forum member, this is how we (he) fixed mine as well. I put a whole new wheel bearing assembly with all new studs on after my stuck stud was drilled out. Actually put new wheel bearing assemblies on all four corners.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Nov 23, 2006 | 02:20 PM
Rou-Rou 03's Avatar
Rou-Rou 03
had the same problem with my prostreet 66 pickup need to grind a flat on the top of the lug center punch the center and start with a small drill bit . drill only as deep as the nut depth. progress to larger bits till you get to the treads in the lug. you should then be able to get it of with a lug wrench ps if stud trys to turn while drilling just hold the nut with an open end wrench. take your time and drill straight good luck
Old Nov 23, 2006 | 11:33 PM
Dirty Howie's Avatar
Dirty Howie
This happened to me too !!!!!
The Dealer was able to cut it off without damage to the wheel....
.....but they damaged my pocket book by charging for a whole new wheel hub
DH
To Need ideas for removing a stipped lugnut
Old Nov 24, 2006 | 09:55 AM
gt-hunter's Avatar
gt-hunter
Thanks for all the good info guys....
Still working on it without success.
I've tried to drill the actual stud itself since I can't get the lug to catch any threads on the stud.
However, drilling right into the top of the stud chipped a titanium coated metal drill bit I was using
What the hell is that stud made out of?
Anyway...I'm going to try to chisel the lug out today and see if it will break off. Hopefully I won't damage the wheel
Old Nov 24, 2006 | 10:28 AM
Secret237's Avatar
Secret237
The stud shouldn't be too hard, they don't make them too hard for fear of them breaking, they would rather have them flex rather than break, so, shouldn't be too hard.
You will want to replace the stud anyways, after you get the wheel off, so drill away, just get a bunch of drills in various sizes, start small and work big. If it's a 12mm stud you won't need a drill larger than 27/64", smaller if your not centered.
Consider not drilling all the way thru the stud. If you did not, then you could use a punch, in the bottom of the drilled hole, to drive the stud out the back, which would be the same thing as pulling the nut straight off, your drilled hole would have to be close to the 27/64" though.
I still like the idea of removing all the other nuts, with the wheel off the ground, and then pulling the wheel to one side while turning the loose nut, trying to catch some threads.
Good luck.
Old Nov 27, 2006 | 01:53 PM
gt-hunter's Avatar
gt-hunter
Thanks for all the advice guys....
The solution turned out to be drilling through the top of the stud until the lug popped off (right on the drill bit anyway)...
I had to actually buy a $15.00 drill bit to actually be able to drill into the stud (man that thing was hard)....but it finally came off.
One thing that I'm wondering is...can the studs be replaced individually or do I have to replace the whole hub?
Trying to punch out the stud will be this weekend's project.
Thanks,
