Headlight Issue
Old Nov 22, 2006 | 11:09 PM
Sethkins88's Avatar
Sethkins88
4th Gear
Default Headlight Issue
hey guys just searched but didnt come up with a whole lot. I just replaced the headlight gear but recently uncovered a new problem. When i go to turn on my headlights the lights turn on but wont flip up. Here is the kicker.. when i turn the vette off and go to turn the lights on.. eveything is normal and lights turn on and flip up.. any clues to what is goin on?
thanks alot
-seth
Old Dec 2, 2006 | 02:09 AM
Sethkins88's Avatar
Sethkins88
4th Gear
Bump.. you guys got any clues?
thanks again
-seth
Old Dec 2, 2006 | 07:07 AM
Oldvetter's Avatar
Oldvetter
Try removing your battery terminals, cleaning them (and the battery posts with a wire brush) and reinstalling them. Tighten to 11 ft-lbs. Too tight will cause leaking battery.
Even if they don't look dirty, do this. IT WORKED FOR ME ! Headlights are very sensitive to voltage.
Old Dec 2, 2006 | 09:09 AM
JC in XTC5's Avatar
JC in XTC5
If your lights turn on but won't come up then it's likely that the headlight control module is getting the correct ON voltage to raise the headlights but it's not.
With the car off, there could be a voltage difference as Oldvetter points out. One thing besides the battery to check is the ground for the headlight control module, which is located at G102 on the frame rail behind the passenger headlight. If the ground is starting to corrode it could result in enough of a difference to raise the headlight.
To Headlight Issue
