rhythmic vibration-
Old Jan 11, 2007 | 01:38 PM
  #41
Billdog350's Avatar
Billdog350
I feel my vibration in the steering wheel, so I thought it was in the front, obviously....but I jacked the REAR of the car and accelerated to 70+ mph and the REAR was VERY obviously vibrating.
Old Jan 11, 2007 | 01:50 PM
  #42
rcknusa's Avatar
rcknusa
I will have to jack it up this weekend and try it.
Old Jan 11, 2007 | 01:56 PM
  #43
AtHomeSoda's Avatar
AtHomeSoda
Default Well....
I don't think a No-Load test is the way to go... most cars, just jacked up no load on the suspention, or tires, will vibrate... The pulsing that is felt at 65-75 on the freeway is really annoying... You would be best to swap wheels and tires with a friend... it is free... if his car does not do it.. and yours does.. you are wasting your time on balance. My 98 C5 has repro chrome thin spokes, and non-run flat Nitto's 555 and it is smooth as silk on the freeway, 102,000 miles. I just bought a C6... so I will be selling the C5 soon... like to keep both... but hard to justify 3 Corvettes.
Old Jan 11, 2007 | 02:20 PM
  #44
Burgie's Avatar
Burgie
How do you keep from screwing up the sensors by doing that? Wouldn't the computer say "Wait a minute, the front's not turning" and also the angle on the rear wheels would change since there was no up force on the tire? It may be possible to do that test with the front as the car doesn't have to be running but I would hesitate to do it with the rears- IMHO
Old Jan 11, 2007 | 03:24 PM
  #45
Billdog350's Avatar
Billdog350
Huh? Its no different than doing a dyno run. Your fronts stay fixed and your rears spin. Your ABS gets pissed off, you need to have traction control turned off, and you get a service traction control error that you have to clear...otherwise its fine.
I was thinking of removing the rear tires, putting the fronts on the rear and seeing if those vibrate too, that would tell me a little more about what's going on.
Old Jan 11, 2007 | 04:00 PM
  #46
Burgie's Avatar
Burgie
what were I tinkin-
Thx
Old Jan 11, 2007 | 06:32 PM
  #47
AtHomeSoda's Avatar
AtHomeSoda
Default Well.... FYI
My C5 has no vibration... I jacked it up, and ran it to 70-75... it had the wheels vibrating, as there is no weight on the tires, and they change shape... unlike on a dyno... where the tires still have the weight of the car on them.... hummmmmmmm
Old Jan 11, 2007 | 07:31 PM
  #48
Burgie's Avatar
Burgie
OK-maybe I'll give a try,,,,my luck the whole damn car will shake off the stands at 75, tear off across the street and take out my neighbors Mustang! Hummmmmmmmmmmmmmmm
Old Jan 11, 2007 | 08:09 PM
  #49
AtHomeSoda's Avatar
AtHomeSoda
Default Well... my point was...
It is pointless to do... waste of time....
Old Jan 11, 2007 | 08:38 PM
  #50
Burgie's Avatar
Burgie
Interesting to look at though? huh
Old Jan 12, 2007 | 12:46 PM
  #51
Billdog350's Avatar
Billdog350
Guess that's not a good test for the rims/tires then. I'm not looking forward to road force balancing....I already visually checked the tires and rims for blemeshes and they seem fine. I'll bring them back to the shop that mounted and balanced them and have them rechecked incase something is funky, since that's the free option...then I'll have to look into road force balancing to figure out where the problem is. I love the look of my 5 spokes over the wagons...I just wish they didn't vibrate so much!
Old Jan 12, 2007 | 12:55 PM
  #52
AtHomeSoda's Avatar
AtHomeSoda
Default Bill...
My guess, unless they did someting really wrong when they balanced the tires, a weight fell off, the used too big of weights, and they hit the brake caliper, and knocked them off.. happens... if the wheels check out...you are looking at drivetrain... I know a lot of people bump a curb... that is all it takes to mess up a wheel bearing..
Old Jan 12, 2007 | 02:24 PM
  #53
Burgie's Avatar
Burgie
On my 98 the Z06 aftermarket wheels check good, the GSD3's are within limits assebly limits, and rebalanced at another shop (not the one that said it was illegal to run non-runflats). The shop did get them better but certainly not smooth-still rhymthic vibration. Two options-try and get an original set of wheels 98-01 and replace Z06 wheels or take it into Chevrolet-pay the 86 bucks to pull the wheels and check the bearings. If bearings are bad, warranty will replace and pay for diagnostic check-if not I pay.
Again some have said, these cars are tuned for specific tire weight and type and anything other may cause problems maybe stands true. Will keep posted if circumstances change.
Old Jan 12, 2007 | 05:19 PM
  #54
Billdog350's Avatar
Billdog350
I didn't give the whole history on my deal. I bought 4 used OEM thin spoke rims off a forum member. Swapped the rear tires and sensors from the wagons to the new thin spokes...then bought new front tires and had those mounted and balanced on the thin spokes. There was ZERO vibration before with the wagons.
The variables in my situation are the 4 rims, and front tires. Everything was balanced, one tire actually came out to 0.00 on the machine (I'm a bit suspicious about that one). The new tires "could" be out of round, rim is bent, or they need to be reblanced...
Old Jan 12, 2007 | 06:45 PM
  #55
AtHomeSoda's Avatar
AtHomeSoda
Default You have Warranty?
Man.... for all the running around... $85 sounds cheap to get it tested... and if bad they fix for free.... my bet... you could get a new bearing or 2 for free...
Old Jan 13, 2007 | 11:39 AM
  #56
Burgie's Avatar
Burgie
50 dollar ded. but thats cheap- considering the car was 7 years old when I bought the warranty and essentially cost me 430 a year to insure against mechanical breakdowns-In this case one hopes for bad bearings-travel easy
Old Jan 13, 2007 | 11:49 AM
  #57
Burgie's Avatar
Burgie
I've got a sneaking suspicion that our problem may be in switching from stock to aftermarket wheels and going to the run flats. The weight difference (non run flats-lighter), heavier wheels, and with the different sizes 17 &18's may have created an imbalance somehow and began to generate a rhythmic vibration. The cars were designed for specific tire and combined weight. If it turns out the bearings are good, its back to originals. I want to enjoy the car and not keep chasing vibrating demons.
To rhythmic vibration-
Old Jan 13, 2007 | 08:33 PM
  #58
AtHomeSoda's Avatar
AtHomeSoda
Default Well.....
Again... I have Repro Chrome Thin Spokes, and Nitto 555 non run-flats, like a ton of other people here on the forum... with no problems.. so... I do not think that is the answer...
Old Jan 14, 2007 | 06:07 PM
  #59
Billdog350's Avatar
Billdog350
I went to NON-RUNFLAT tires and OEM thin spokes on my current setup (that I'm having issues with). You'd think non-runflats and OEM thin spokes would have the FEWEST problems.....
Old Jan 15, 2007 | 11:11 AM
  #60
corvettebob1's Avatar
corvettebob1
Default rhythmic vibration
Frankly I'm beginning to think it has much more to do with the tire it self, more specifically the tread pattern.
I went from runflats on mag wheels (stock coupe sizes) to F1GSD-3's on repro Y2K Z06 sizes.
Frankly the weight factor was a wash due to the size increase and dumping the runflats.
My wheels have been checked and re-checked and road force balanced 5 times at the same Goodyear dealer by 3 different techs.
All with varying results, so it does matter who is running the balancer!
The car has only 53,000 on it and I have had it since it was brand new in 98 and had Never bumped a curb or damaged a tire or wheel in potholes.
Just wondering if there is a Goodyear Rep. we could contact to ride in 1 of our cars.
