2nd Column Lock Since Recall Applied!!!
The very next day, it was locked and had to be flatbedded back to the dealer. This morning, 11 days and about 500 miles later, it locked up again. :mad :mad :mad
It is clear that, for me at least, the new and "improved" column lock hardware is worse than the original. Since the new hardware is not compatible with the old bypass, I strongly urge everyone to decline the recall service (if you are lucky enough to be asked ahead of time) and go with the C5 Solutions bypass instead.
FYI & FWIW...
Especially after C-5 Solutions emailed the following to some of us:
Two reasons the bypass is incompatible with the recall:
The harness that the bypass plugs into gets rewired which prevents the bypass module from connecting to the BCM like it needs to.
Also, having the GM bypass relay and my bypass module together may conflict with each other at some time. I haven't bought one of theirs to really analyze that.
If someone ACTUALLY HAS been able to use my bypass module after the recall, I'd really like to know about it.
Also, have any '02 owners installed my bypass module? I haven't been able to determine if the recall was applied at the factory during production.
Soo I am in a search for the $8.00 part number for the wiring harness they replaced. I would at very least have the dealer give you the old relay wiring or order you a replacement.
Good Luck.. I have had the revised lock in my car with no problems in 3 months.. Sorry to hear about your problems.. I would try another dealer maybe it is an install problem.. :flag
And you could probably save a lot of money having your oil changed someplace else too, I'd never let my dealer touch the car unless it's for something that I can't do myself or it's a warranty item.
The worst part is that I think this is going to have me trading in the C5 on a different car as soon as possible. After I calmed down the first time, I told myself that mistakes can happen, and perhaps it was a bad installation job, and that the Corvette was and still is the best fit to my needs by a very large margin. But now that it's happened twice, I have to believe that the design is fundamentally flawed. And, since this is my daily driver and I can't keep missing work to deal with this, it's fatally flawed. So I am going to have to find another car, one that won't be as close to what I want as the vette is. And with the recent market tumble, there couldn't be a worse time for me to be car shopping, as my "new car account" is way down from where it was a couple of weeks ago, and will probably take quite some time to recover. <sigh> I may have to go with a cheap interim car for a year or two and then look around and see what's available.
SD
I haven't owned a car yet that was perfect. Forum members push their cars hard and it's pretty impressive that this is one of the few things that goes wrong.
SD
The dealer won't install the bypass for two reasons. First, the bypass is not compatible with the new hardware. Second, the dealer is not permitted to install anything that disables or otherwise interferes with the operation of this "feature", which I understand is in place, at least in part, to meet legal requirements. I have them looking for the old column lock hardware for me, which I will have installed myself at a non-dealer, along with a bypass. I don't know if they'll be able to find it.
In the 25 years I've been driving my own car, I have had exactly 3 times where the car wouldn't start and had to be towed for repairs to revive it (as opposed to needing a jump, or needing to sit to clear flooding, or similar minor things). All 3 times were this 'Vette, for this reason.
Don't get me wrong: I love this car. No other car offers a combination of performance, practicality, and price that is anywhere near this one. But if I can't count on it, it's unacceptable. Yes, I know, I could get a second vehicle and drive that anytime reliability was important. But that would mean that the 'Vette sat idle most of the time. I'd rather have a car that wasn't quite as perfect for me, but that I could drive all the time.
)Also, does anyone know how the computer detects the position of the plunger? If it's looking at the plunder, then simply cutting it off could cause problems (which Mallett may do something about, but I'd need to know what). Hmm. I may have to start with an e-mail to Mallett - I hope they're better getting back to me on this then they where when I was trying to by a set of wheels...
I have and am keeping the C5 CLB on mine.
One thing seems abundantly clear: no one, not Mallet nor GM really knows what is happening. The GM "fix" is worse than the original system.
One other thing also seems abundantly clear. In all the time I have been monitoring the forum, I have not seen one single post reporting any problems with the bypass solutions so many forum members have installed.
(IF I AM WRONG HERE PLEASE LET ME KNOW!)
I asked Mallet to install the bypass in addition to doing their thing with the plunger. While avoiding the loss of control while moving is the most important, avoiding being stranded is pretty important too.
Sorry you're having trouble getting your parts back since that seems the best solution. Maybe you'd better start talking about legal action. In the meantime maybe a new bypass is being designed to work with GM's new fix. What an incredible clusterfock!
[Modified by TCSF, 2:09 PM 9/25/2001]
Eric
-Jeremy
