throttle body question
Old Nov 27, 2006 | 09:20 AM
DScott600's Avatar
DScott600
Default throttle body question
I was wondering what the hose on the top of the throttle body on the passenger side goes to? Is this a vaccume line, and if so is this where you would add the GM top end engine cleaner if you are doing the decarb procedure?
Old Nov 27, 2006 | 11:27 AM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
PCV hose inlet. Should connect to both valve covers near the firewall. For the decarb routine.. use the big vacuum line on the brake booster. Pour slowly.
Old Nov 27, 2006 | 12:33 PM
vettenuts's Avatar
vettenuts
Why not use the fitting towards the front passenger side of the intake (neck it down so the motor will run) or the EVAP connection on the driver's side? The brake booster line would have trouble feeding the front cylinders.
To throttle body question
