you will need to relearn your key fobs.. and if you have set a security code in your radio.. you will ned to know what that code is .. to unlock your radio
Re: C5 Tech, Battery install, Then what? (Evil-Twin)
Thats not to bad, I know this original battery is on borrowed time. One note here, I can't find the optima battery around my town. The exide orbital, same thing, meaning no acid in the battery to leak down onto computer stuff, is $ 129. I have never had a problem with a die hard gold battery, better guarantee, and only $ 80. So I'm wondering here...Skip :chevy
I've never tried this, but you could try one of those devices that supply 9 or 12 volts back through the cigarette lighter. You could also jury rig one from an old radar detector or phone power supply plug and any battery over 9 volts. (I bet 9 v will keep the memories viable.) Make sure you get your polarity right. I think the center electrode is positive, but if I were doing this I would verify with a volt meter. Maybe someone else has done this and give you the benefit of his experience.
you will need to relearn your key fobs(DID NOT HAVE TO DO THIS ON MY 99 ).. and if you have set a security code in your radio.. you will ned to know what that code is .. to unlock your radio
I have a 12 volt plug-in from an old fan that I put alligator clips & color coded that I have used on several prior cars (an ASE tech taught me this ) and I hook it up to an old lawn tractor battery & plug into the cig lighter. Never have had to reset anything unless disconnecting to clear codes.
