Stripped a Nut
Old Nov 27, 2006 | 03:10 PM
B-rent's Avatar
B-rent
Default Stripped a Nut
I was trying to take off the nut holding the upper drivers seat belt bracket but the nut got stripped and I cant get it off Ive tried WD-40 and vise grips, sockets for removing stripped nuts, ect. But that metal is so soft I do more harm than good. Any other Ideas how to get it off? Im installing a harness bar so I'll have to go to the hardwar store or something later to get a new nut anyways.
Old Nov 27, 2006 | 04:00 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
is that the big torx bolt?
Old Nov 27, 2006 | 08:19 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Those torx bolts are really tight. Have you tried a big set of vice-grips ?
If that does not work I would go over to a local muffler shop with a bolt that is simular in size to the head of the torx bolt and have them spot weld in on.
To Stripped a Nut
