VaraRam Install...
Nov 28, 2006 | 02:32 PM
From: Centerville OH "If we weren't all crazy we would go insane"
CI 3-4-5-6-7 & 9 Veteran
St. Jude Donor '08
VaraRam Install...
"Step 1. Disconnect negative battery cable."
Why
Nov 28, 2006 | 02:40 PM
Because in the steps following, you'll disconnect the MAF and disconnecting the battery is just a safety precaution when pluggin'/unpluggin' electronics.
Nov 28, 2006 | 02:43 PM
Certainly not necessary, so if you are inclined to skip that step, feel free.
Nov 28, 2006 | 07:13 PM
To be 100% safe disconnect it. I didn't and everything was fine. Risk management told me that I would be OK at 99.98% safe.
Nov 28, 2006 | 07:15 PM
Quote:
Why
All stupid service procedure start with this.. Hell I barely disconnect the battery if I am replacing a PCM...
The only time not doing it ever bit me was when working on the Starter.....
Nov 28, 2006 | 08:41 PM
St. Jude Donor '07-'12, '20
Quote:
The only time not doing it ever bit me was when working on the Starter .....
Damn man, next time your doing something like that, call me.
I would love to see you get BIT
Nov 28, 2006 | 09:10 PM
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
My wifes old Infiniti J30 had the dipstick right next to the positive battery terminal. Let's just say I found that out the hard way.
Damn near gave me a heart attack.
Nov 29, 2006 | 12:38 AM
Why
To put the PCM in re-learn mode. Take your car out for a 50-100 mile drive so it can 'learn' to use the extra air flow.
Nov 29, 2006 | 07:30 AM
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Now that sounds like my sort of luck, sharpens the senses
