rear view mirror Electrical
Old Nov 29, 2006 | 11:46 AM
ahr69's Avatar
ahr69
Cruising
Default rear view mirror Electrical
My rear view mirror's center button which, when pushed, lights the dash is NOP,aswell as the automatic dimming option when a person with hi-brights is approching from behind. The drivers and passagers lights both work, the mirco fuse under the passagers side is good. The harness that is pluged into the mirror the brown and black connectors (wires) are both showing netural, from memory the brown should be hot. Thats were the problem is. Does anyone know where the fuse is that runs that part of the mirror. Again, other than the one listed in the users car manual? (found in the fuse box under the dash on the pass side.
