Changing Belts on C5
Old Nov 30, 2006 | 01:59 PM
Point & Shoot's Avatar
Point & Shoot
Default Changing Belts on C5
Please go easy on me but how hard is it to change the belts on a 2001 C5?
I've done my oil pressure sensor & plugs and wires so should I attempt the belts or have it done?
Old Nov 30, 2006 | 02:19 PM
94legaleagle's Avatar
94legaleagle
shouldn't be a problem - put a wrench on each of the tightener bolts (the one that goes thru the tightener wheel), apply force to turn wrench clockwise I believe - this causes the tensioner to loosen and remove the belt
Replace is opposite - shouldn't be any big problem,
Old Nov 30, 2006 | 03:48 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
If you can handle an oil pressure sensor swap you can handle swapping the belts.
Old Nov 30, 2006 | 05:36 PM
Point & Shoot
Dan_the_C5_Man thanks for the encouragement.
Can you describe what you do with the belt tensioners to release the tension & also, I'm concerned about the A/C belt as it looks like it could be a bear.
I would appreciate any advice.
Old Nov 30, 2006 | 07:39 PM
Patches's Avatar
Patches
Put your socket on the pulley tensioner as if you were going to tighten it - and do just that. As it rotates the pulley, it will relieve the tension on the belt, allowing you to slip it off.
The A/C belt can be a bit tricky. Tackle it from underneath using the same technique.
Old Nov 30, 2006 | 07:42 PM
FLORIDA's Avatar
FLORIDA
St. Jude Donor '07
Nice and easy.
Old Nov 30, 2006 | 09:43 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
Mine shreddded off on the Kerbeck toys for tots run. Easiest thing I've ever done. Had help from two forum members with a spare belt, when I got home I bought a new one, and it literally takes 5 minutes to change
Old Nov 30, 2006 | 09:46 PM
DngrZne's Avatar
DngrZne
The a/c belt will be the difficult one. If it looks like it won't loosen up enough to get the belt on, really lean into it and it will move that little bit extra and the belt will slide on.
Old Nov 30, 2006 | 11:16 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
the a/c belt can be a pita on the A4 cars w/ the trans cooler lines going in front of the tensioner
Old Dec 1, 2006 | 11:12 AM
2kbluestreak's Avatar
2kbluestreak
The "trick" for the long accessory belt is to do the water pump last. Its conical shape allows the belt to be slid on while the idler is held back. The biggest pain with this belt is getting it to loop around the fixed idler pulley between the crank and PS pump.This is something I would not want to do on the road at night in a cold rain.
To Changing Belts on C5
